Oil for the tC
Old 06-04-2009 | 03:57 AM
dangerranger21's Avatar
Default Oil for the tC
What are all you buffs using for oil in your tC's? I have been using the 5w20 syntec stuff which has seem to been pretty nice but every 3000 miles or so before an oil change the oil is low like where I need to add a half quart or something its not burning or leaking oil as strange as that sounds I have triple checked everything I bought the car brand new it has about 50k on it now so I am just wandering maybe that oil is too light for the car? just so light its seeping through spots? Cause it is a pretty light oil. Any suggestions would he great thanks!
Old 06-04-2009 | 04:06 AM
draxcaliber's Avatar
whatever it says on the oil cap is what you're supposed to use.
Old 06-04-2009 | 05:35 AM
danboriss's Avatar
i run Mobil 1 10w30. Walmart never has the 5w20 in stock.
Old 06-04-2009 | 05:49 AM
dodaddy's Avatar
5w30 royal purple for my car
heres a thread on what boosted people are using if your interested:
https://www.scionlife.com/forums/vie...212&highlight=
Old 06-04-2009 | 06:58 PM
nodsetse's Avatar
Default Re: Oil for the tC
Originally Posted by dangerranger21
I have been using the 5w20 syntec stuff...I am just wandering maybe that oil is too light for the car?
No, it's not "too light" for the tC, I've used it myself and prefer it over anything else. If you're really concerned, you could run the 5w-30 with no worries.
Some engines simply use more oil than others, often due to the differences in manufacturing tolerances. Half a quart in 3000 miles is nothing to be concerned about (older cars had somewhat of a defacto industry standard, where anything less than a quart in 1500 miles was acceptable), provided it's consumption doesn't increase beyond that.
Old 06-04-2009 | 11:04 PM
TRDIZZLE's Avatar
i'm running 5W-30 and haven't had any problems with it. i was running 5W-20 before but i haven't really felt any difference.
Old 06-04-2009 | 11:12 PM
Ace83's Avatar
Ronin Scion
read the oil cap.. the only time you should change is when you modify the car
Old 06-04-2009 | 11:15 PM
AAG's Avatar
AAG
DeepSouth Scions
If its not leaking the oil than it has to be burning it. You might try to up to a 5w-30 oil and a different brand to see if it helps. I'd try Mobil 1 or Pennzoil Platinum.
Old 06-05-2009 | 03:04 AM
TTCCC's Avatar
Does everyone change at 3K ? The manual says 5K.
So if 5K is OK on "regular oil" why in the world you run sync and change it every 3K ? Seems like a waste to me (unless your turboed).
Oh wait, i know why because a lot of people feel they know more about Toyota's engine then Toyota themselves !
Old 06-05-2009 | 03:32 AM
SCIONshane's Avatar
Big Sky Scion
3k if you can afford to do it that often. But 5k is fine too.
Old 06-05-2009 | 03:50 AM
Jon's Avatar
Jon
Moderator
Moderator
I use Mobil 1 5w20 synthetic.
Old 06-05-2009 | 04:43 AM
BZinn1's Avatar
for the oil you are using you can go 5000,plus just check the oil every so often and add a little for what is being burnt,it is normal.if you hamer on the motor,then it will burn more and need sooner changes.
Mine has finally started to use about 1/3 quart every 5000 miles,figure when I hit 50000 miles it will be using a 1/2 quart........it is normal,now just be sure to keep an eye out for leaks,they will be apparent,trust me you will see them,once you start leaking you need to wathc it and at worst change the seal it is leaking from .........depending on where it is it can be easy to pain in the butt........
toyota motors with regularly changed oil are gonna last a long time though,they are over built and under powered for what they will take.
step up to 5w30 and you will be bette off as that is what toyota recomends to use.......
Old 06-05-2009 | 05:53 AM
lvlonkey's Avatar
so the oil cap says 5-20 but toyota recommends 5-30? thats weird...
Old 06-05-2009 | 08:15 AM
SFTifoso's Avatar
Motul 300V 5W30. I'm gonna do a used oil analysis around November to see how well this pricey as hell banana juice oil performed. Also a note for you Mobil 1 guys, use Mobil 1 Extended Performance, not the regular stuff. Reason? Regular M1 is not a true synthetic anymore. Exxon has taken a page out of Castrol's playbook and started using extensively refined petroleum oil that, under US law, can be called "synthetic". M1EP and Castrol Edge (different from Syntec) for that matter are true synthetics.
Old 06-05-2009 | 09:53 AM
AcidDrop's Avatar
5W-20 Royal Purple with a K&N oil filter, i check at 3k how the oil is and then go from there because if it has plently then i keep checking it every 500 miles but i usually just change it at 4k or before 4500
Old 06-05-2009 | 02:33 PM
a_german_named_hans's Avatar
Royal purple 10w30 i think i used. or 10w20. which ever is on the cap lol.
Old 06-05-2009 | 03:35 PM
lvlonkey's Avatar
ah thats really good to know.
Old 06-05-2009 | 04:25 PM
AAG's Avatar
AAG
DeepSouth Scions
You are wasting perfectly good oil and filter if you are changing it that soon. You can run those for 7.5k-10k miles.
Old 06-05-2009 | 04:29 PM
Jon's Avatar
Jon
Moderator
Moderator
Toyota changed the recommended oil in 07 I believe. My 06 says 5w30 but my friend's car says 5w20.
Old 06-05-2009 | 04:40 PM
Motor changed a bit in 07.
