Power Outlet - in Console - No Power!!
Old 12-16-2005 | 02:27 AM
LGS-Static's Avatar
Default Power Outlet - in Console - No Power!!
ok.. when I first got the car.. I used the center console plug (in the armrest) for my cell phone.. worked fine.. could plug it in / unplug it no problems. then.. it stops working..
brought it to the dealer.. they said the fuse blew.. and changed it.
as soon as I plug the cord in.. bam.. does it again! and again!
Dealer tells me the key should be off before u plug in!! wtf is that?? that has to be the lamest excuse i have ever heard.. I dont EVER have to turn off the car for the outlet under the radio! and it has never blown...
anyone else with the same problem?
should I just up the amps on the fuse?
Thanks!
Old 12-16-2005 | 02:38 AM
Krayzie_Los's Avatar
possible defective cell phone charger....
try the charger in the front cig outlet and try a different plug in the center outlet
has the center console been removed recently? if so, the wire could be shorting out when everything was put back in.....
other then that, i have no clue
Old 12-16-2005 | 02:46 AM
LGS-Static's Avatar
phone charger works fine in the front plug...(only way I can use it now!!! lol)
and no.. I havent taken anything apart in the car...
thanks for the ideas though
Old 12-16-2005 | 03:47 AM
engifineer's Avatar
Sounds like something has gotten into the outlet, so that when you plug something in it shorts, blowing the fuse. Either that or something has broken in the outlet causing the same thing. Try another car power adaptor, if it blows the fuse as well, take it back and ask them to check it again and replace the outlet if necessary.
If you can plug it in, then turn on the key without the issue occurring... AND it does it with other devices in the same way, then I would say there is something mechanically wrong with the outlet, as I mentioned above.
Old 12-16-2005 | 04:14 AM
LGS-Static's Avatar
Alright , I will give it a shot...
it would be lame if it was really an issue with the outlet, since my buddy is the guy at the dealership who told me the "key off" issue...
thanks!
Old 12-16-2005 | 04:26 AM
oh yea, forgot about that one...like he said, check inside the outlet itself
Brimmer555
05-31-2015 03:31 AM
CrowJenkins
05-04-2015 05:52 AM
missing_image
02-07-2015 08:18 PM
crystaljukebox_com
02-05-2004 06:53 AM
fliggah
12-25-2003 02:03 PM
