replacing the key fob
how much does it cost from scion to replace a key fob?
also is it possible to buy one of those ebay flip up keys (same ones vw's and mercedes uses)
and program it to work with the tc?
Re: replacing the key fob
Second, you cannot reprogram a FOB as a customer. You might be able to learn a Toyota or lexus key to the scion, but you will not be able to program a non Toyota Brand key to the tC. Nor can you reprogram any non Toyota FOB to work with the tC. And not all Toyota fobs will work with the tC anyway.
Third, Assuming you do #1, you will have to work around the immobilizer. You can get an immobilizer bypass for the car and solve this problem. what happens is they stick the immobilizer coil from the keyfob near the actual immobilizer so the car thinks a real key is always there. If you do this you can start the car with any non-immobilizer key.
To get the flip key and have an immobilizer you will have to
A. Try and put the electronics of the tC keyfob into the new fob
B. Glue the tC fob onto the new flip key
Putting the electronics into a new key will be extremely difficult because buttons won't like up and the case of keyfobs are usually form fit with no room.
Hope this helps, if you have any other questions feel free to ask.
Originally Posted by slboettcher
Never thought there was that much to learn about keys!
Scott
Iam unfortunatly one of those engineers...
And I swear that if that kid misses his free-throw your UNLOCK button isn't going to work in that instance
mischadoll
03-09-2015 05:48 AM
