Sound/Vibration from tire
So for the past 2 months or so my front right tire has to noise and vibration that only gets louder with speed. I'm wondering if is the wheel bearing but on a 17k car tho?? Any thoughts?
Originally Posted by fujita_TC
get it re-aligned or rebalanced, or do both, and also check your lugs if all of them are still there, tighten them too...
and any chance u took off your wheels after you got your alignment, since once you remove your wheels then u have to get iit aligned again...
take it in to have the balance checked. also check the tread on that tire by running your hand over it. If there is cupping or wear in odd places, definitely the alignment. Weird treadwear would definitely cause noise. check that and get back to us.
i just told them there was a vibrating coming from the right front tire and when ever they wheel was turned to the right it would go away. I think they did the lift the car and spin the wheel. Took them 45mins to change it as they had one there for another Tc but the owner was out of town for like 2 weeks. So i only spent 2 hrs at the dealership
I didnt think it was my bearings tho on a car with only 18k on it. And I didnt hear the usual whining noise with it.
i have this same problem. my dad thinks its the bearing also , we put the car on jacks on the left wheel makes noise when i put it in drive. Did you know how much the job costs? (i know it was covered by warranty but i dont have warranty anymore).
i think it's about a 1-2hour job. plus the part of the bearing which is about $30. have to take the steering knuckle, brakes, drive shaft nut, ball joint, off. and then press in a new bearing into the steering knuckle. something you should definitely have a pro do.
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
01-18-2016 08:41 PM
