Steering wheel shaking. An allignment problem?
whenever i travel at about around 70-80 mph on the highway my steering wheel begins to shake a bit, especially as i accelerate fast to those speeds. it's not horrible ( i know what it feels like to have unbalanced tires because i had that with a rental car once) but it is noticeable and a bit annoying. i have custom 17" wheels and tires on my tc and i have had them balanced 3 times by different places and i bought hub centric rings to fill in the small gaps that used to exist. the shaking used to be a lot worse to the point that it was unignorable before i got the hub centric rings. after the rings were put on it reduced a lot but i still get a bit of shaking at the speeds i said above. it could be the road because i mainly travel the same highway everyday, but i don't know.
could this be an allignment problem? should i take it to the dealer to get the allignment checked, or are they going to give me a hard time about having custom wheels and tires and blame it on them? also, do you have to pay to get the allignment checked or is it under warantee or something?
Ummmm to me that sounds like tires...if it was the alignment wouldnt it pull to one side or the other? i could be wrong..but usually the shaking is from in improperly balanced tire.
Correct me if i am wrong.
If it was during braking, it would probably be a warped rotor but since it's just during acceleration that can't be it.
oh yeah, i forgot to mention that the tires were looked at also by the 3 different places and i was told nothing is wrong with them. and i was told that the wheels are ok and not bent or something like that. that's why i have no clue why i get the shaking.
anyone else get any kind of shaking at speeds like that on roads?
do you live in a place where you drive over many potholes? its possible that you blew one of the control arm bushings. That was the problem on my 93 Altima, There are 3 bushing that hold everything together, and if they all break, your whole axel breaks free and well.... im sure you can figure out the rest.
I'm a tire-professional (sad huh?) Anyhow Scooby nailed it...tire ballance, probably threw a tape-weight. Any tire shop can fix it. Sears is a 14.99 ea for 17's+ but its lifetime balancing.
If you need to save cash, just have the fronts balanced..because feeling it in the steering wheel indicates fronts (your butt shaking indicates rears).
Then again, visually check out the tires too...might have a bubble forming.
i have the same problem around these speeds.
Have you checked/monitored your tire pressure? if it is too low or high it will tend to throw the wheel out of balance a bit.....
If that doesn't help, hmmmm I get the shakes too around the same speed...
Originally Posted by neeferea
What tires do you have? You know I have problem with my tires. Car shakes at speeds 80-90+. What tires do you have?
By the way you can get a free alighnment at toyota . It is under war. , but only one is.
You need to go to a shop that has a hunter road force wheel balancer. The shop has to have a GSP9600 Road Force Measurement System. Go to www.hunter.com and go to products and then wheel balancers. There is a link to solve wheel vibration problems: locate a GSP9700. This will solve your problems. All other solutions will not work.
This can more that just a wheel balance problem, could be bad bearings, flat spots on tires, off axis rims, etc. Just because you cannot see a bent rim doesn't mean the rim is not defective. The road force machine will take all the guess work out of this issue.
as far as the tire pressure thing goes, that's an interesting suggestion. i had these wheels and tires on another car for about 6 months before i got the tc. while they were on the other car, one day, last summer, i noticed that one of the tires was very flat looking. i thought i had a slow leak so i took it in but they said that they couldn't find anything wrong with it. they water tested it in the tank for holes and nothing was found. air was put in and it was ok for the rest of the time it was on that car. it was the tire that was on the left front side, and i don't remember any steering wheel shaking. maybe there really is a problem, or one developed.
Originally Posted by slowpoke
What lugs are you using on these aftermarket wheels? Your oem lugs or are they aftermarket lugs.
okay, that clears that up, if the rim isnt bent i would guess that the balancing is bad, or that the tire pressure isnt correct. take it to discount tire, they will probably look at it for free. they usualy are good about that kind of stuff.
CombatmedicR56
11-12-2020 01:53 AM
fur_pig
03-20-2020 04:28 PM
Beesh
01-09-2015 06:30 PM
