Sunroof isn't closing like normal
Anyone had a problem with their roof on their TC not closing all the way? This just started with my stepdaughter's TC. I'm going to take it to my dealer, but I don't know how long it will take to fix. It will shut, but you have to hit the close button in repetitions when the front of the roof is about to fold down. Didn't think I was heading back to the dealer, but oh well. I was there a few weeks ago to get her key replaced. Key was damaged, it just broke apart. Damn kids.
this isn't normal?
i had a problem with my wind deflector not going down, so the sunroofs pinch guard would kick-in and fully open the sunroof again, the dealership lubed and adjusted the track to fix it.
but i thought it was normal that when your closing the sunroof from all the way open, it would stop at a pre-set position with just alittle opening towards the front of the roof? and then you have to hit the close button again to make it fully close? i thought that was normal? or do you mean you are literally sitting there hitting the sunroof close button over and over again to get it to close all the way?
Originally Posted by SquallLHeart
did it want to reopen?
if so.. you might just need some lube.
Yes, it reopens fine. Just when closing it, it goes back in reverse when it's coming where the two bars inside of the roof are about to lower so the front of the roof can fold down. It sounds weird, but thats the best I can explain it. Im sure I can get it fixed. Just a glitch.
[quote="draxcaliber"] this isn't normal?
but i thought it was normal that when your closing the sunroof from all the way open, it would stop at a pre-set position with just alittle opening towards the front of the roof? and then you have to hit the close button again to make it fully close? i thought that was normal? or do you mean you are literally sitting there hitting the sunroof close button over and over again to get it to close all the way?[/quote
I think that is what the problem with my TC is. You mentioned about the wind deflector not going down, so the pinch guard would kick in, then it reopens. So I will definitely tell my dealer about this and will get them to lube it and fix this glitch.
See, what I meant to state earlier is that when Im about to close the roof, I can only fully shut it by punching the close button repetitively. Thank you so much for your help! I really appreciate it.
Originally Posted by draxcaliber
yeah, like i said, it is the pinch guard reacting because the wind deflector won't go down, take it to the dealership, doesn't take long to fix.
Thanks again for your help and advice! If I ever have any problems or questions I usually always come to ScionLife first. Take good care my friend.
Damon
Re: Sunroof isn't closing like normal
I had a similar problem. I first noticed it this winter one day when I was sitting at a light and snow was blowing in my car. There was a quarter inch gap that wouldn't close. I took it to the dealer and they had to replace the entire sunroof.
I've found that when it is especially hot out, the sunroof won't go down unless I manually hold down the wind deflector. I haven't figured out why the heat does this exactly but for now I'll just hold it down with my hand while it closes on sunny days and deal.
My sunroof used to not close all the way so when i would drive on the freeway i ended up hearing some wind come in (as if it weren't closed all the way) i disconnected the battery and reset all my windows including my sunroof, and when i reset the sunroof it closed fully, and NO MORE WIND NOISE!
I've also had this same problem and will probably point it out at the next oil change here in a week or so. It hasn't really been a big deal for me though just hold down the wind deflector and it closes tight every time.
I had the same problem, posted a thread about it, and had good advice.
https://www.scionlife.com/forums/vie...690&highlight=
I fixed the problem myself.
mc1114
Scion tC 1G Aero & Exterior
04-23-2020 10:34 PM
