tC Alarm Chip Location?
Hey guys, I was informed at the dealer the other day that all tC's come with a built in alarm. I guess what they do
if you don't want it, is take out a chip somewhere in the car and that deactivates. I found a site that sells the chip for $295.
Does anyone know where this chip would be located?
Thanks
___
Thanks
___
Originally Posted by th3s3x
hey guys, I was informed at the dealer the other day that all tc's come with a built in alarm...i guess what they do if you don't want it, is take out a chip somewhere in the car and that deactivates....i found a site that sells the chip for 295...does anyone know where this chip would be located?
Thanks
Thanks
Alarm is an dealer installed option
Its true sort of but its not really an alarm. It's called an Engine Immobilizer and basically
it's impossible to hot wire from my understanding its standard on all the tCs.
__________________
__________________
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
I've got my security system installed
naw dude.
they put madd wires and put em everywhere
window breaking sensor, lock, unlock alarms, chip in keys(i think that's what gets activated), they put about 20 wires hook up right next to clutch behind the left foot rest.
the only reason why i got the scion security is to keep the origianl remotekey
if you get other brands you won't get to use them and plus extra heavy remotes
but on the other side, you get the impect sensor which goes off whenever,(thunder) to the little things(I know you can change the sensitivity) which is good when people would like to touch your car alot when the car is fairly new + the ultimate paging system which i envy...... but.. little trouble you may get, short circuits and some problems that takes your waranty away.......
thing i hate about the oem system is they do not make none of that "beep beep" sound, it is just "blink blink"
well it is up to you but i totally like my alarm...so.
naw dude.
1) All tCs have engine immobilizers. That means if somebody tries to hotwire it or start it with anything but one of your keys (either the two with the keyless entry remotes or the valet key) it will not start. The keys have chips that disable the immobilzer.
2) I believe there is a way to hook up an aftermarket alarm so that it arms and disarms using the original keyless entry remote. I haven't heard of anybody doing it, but there's no reason that a good installer couldn't.
Only way to steal a tC is to tow it away. The alarm has a glass breakage sensor, so when someone tries to pop your window or door to snag your 6 disc, it whines like a stuck pig.
Hit the panic on your keyless to give it a listen. Even outside, it's really, really loud.
I decided not to go with the factory alarm. I think you can get a lot more from an aftermarket alarm for the same price. But anyway, I got a Viper alarm hooked up at Auto Addictions in Jersey. While I was there I asked the guy if they could wire the Viper alarm to run of the factory key, using the lock, unlock, and panic features cause I really didnt want to have to use another remote key pad. But anyway, he said it is possible but the range on it sucks. He actually showed me and wired it up and you physically had to have the key against the car for it to work. So I decided just to go with Viper remote because the range on it is great. Hope this helps.
tC VIP parts include a wiring harness and two modules that fit up behind the glove box and of course the security light w/ glass break sensor
Scion System has same features as aftermarket. . .. except remote start. . .. but I have a manual, so nix that
z
__
z
__
Really???
Does the Scion Security have all of these features????
Intrusion Detection
Audible Warning
Passive and Active Arming
Starter Disabler
Panic Feature
LED Status Indicator
Dome Light Illumination
Valet Mode
Flashing Parking Lights
___
Intrusion Detection
Audible Warning
Starter Disabler
Panic Feature
Valet Mode
___
I got a Clifford Alarm the next day after i got the car.
The security system on the tC consists of keyless entry, and a chip in your key that won't allow any other key to start your car.
On the other hand, if you add a aftermarket alarm like the Clifford, you have the option of paging system that will
have vibration sensor, paging system, as well as window roll down and remote start. (I'm not really sure of the remote start)
___
___
.. it has everything that chefman listed, .. except the valet mode .. .. . .. do you have to tip for that?
Intrusion Detection
Audible Warning
Starter Disabler
Panic Feature
Valet Mode - na
.. . has all other features, i know because i installed mine and tested each feature and also programmed the passive alarm which is pretty funny sequence of locking/unlocking doors and locks .. .
. . .what quikgw is talking about is the basic keyless entry and ignition cutoff that is standard in all tC's . .
Intrusion Detection
Audible Warning
Starter Disabler
Panic Feature
Valet Mode - na
I've been reading all of this and now I'm debating the stock alarm system.
Do the people who have the stock system like it? ...and feel comfortable with it?
I had originally planned on purchasing an after market system for the purpose of remote start, etc...
But if the stock system is of similar quality to an aftermarket system it may be better to just add the remote start if I still feel like I can't live without it after getting the new car??
If anyone wants a kick ___ alarm for their Scion and really cares about their car and wants a hell of a discount on insurance. Then go to Best Buy and pick up a Viper two way alarm. I work there.
It'll notify you up to a 3/4 to a mile away if anything is going on. (There is a LCD screen on the remote) Also you can unlock your doors from a long way away. That is what I'm getting when i get my tC.
___
___
