TC Projector Fog lights installed.
Old 12-03-2005, 03:11 AM
DelMarVa
surfripcurl's Avatar
Default TC Projector Fog lights installed.
I installed a set of Hella Projector fogs in my TC TOday... and they seem kind of dim for Projectors... am i supposed to relay them to get them more power or is it typical for them to be like the same color as my regular tc low beams? i do all car audio, so i dont know much about lights... i just hooked them up 12V to a switch... SHould i use a relay?
surfripcurl is offline
Old 12-03-2005, 03:16 AM
ycart1201's Avatar
all the aftermarket fogs ive installed have come with relays. I dont know if that will make them brighter or change color... but it seems pretty std. Got any pics?
Nathan
ycart1201
ycart1201 is offline
Old 12-03-2005, 03:41 AM
DelMarVa
sure man i just went out and took some pics for ya
Old 12-03-2005, 03:42 AM
jasonbegin's Avatar
what kind of bulbs? are in them? and are u sure that the bulbs are completly Center...
if there not completly Straight in there, they look dimmer
jasonbegin is offline
Old 12-03-2005, 03:43 AM
DelMarVa
cool thanks for the tip... i am about to post these pics... i also noticed the right side is brighter than the left
Old 12-03-2005, 03:45 AM
DelMarVa
night time pics after install
jasonbegin's Avatar
sounds like a bulb problem, or its simply the bubls are not sitting in there right, im having the same problem with my Hid's in my Tc, im sending them out to be fixed sunday,
its a B!T c h
Old 12-03-2005, 04:24 AM
JW2
JW2's Avatar
you should use a relay and pull your power straight from the battery
JW2 is offline
Old 12-03-2005, 04:38 AM
DelMarVa
it is going from the battery to a switch... u have to use a switch.. if i use a relay what is that doing for me???
Old 12-03-2005, 07:02 AM
rAndal's Avatar
I believe the relays are designed so that a switch doesn't have to take a full current load.
rAndal is offline
Old 12-03-2005, 12:58 PM
DelMarVa
anyone gonna tell me how they look? i posted pics cause someone wanted to see... but i have no response...
Old 12-03-2005, 03:08 PM
speddlysmitt's Avatar
I like them, Can you post pics in the day with close ups.
speddlysmitt is offline
Old 12-03-2005, 03:31 PM
Limey's Avatar
The fact that they are projectors has nothing to do with the light coming out. The number of AMPs and the Bulb type does.
If these are the H3 bulb, 55amp hellas that i use to have, then yes that the way they look. It was one of the reasons I switched to the 9006 55amp IS300 fogs (bigger light).
Also don't forget that fogs are onlt 9" off teh ground, so you won't get low beam output looky likey even if they were 100w.
I toyed with upgrading my bulbs to 100w, in fact i have a set sat on a shelf here that i should really unload. But I was chicken that i would melt something so i didn't.
One thing to be very aware of with those fogs, make sure they are below horizontal. Or you'll blind everyone coming the other way.
Find a flat space, park the car 15' or so away from a vertical wall, meaure the top of the bulb to the ground (roughly) then measure your cutoff on the wall. It should be lower that the first measurement. If it's the same or higher, you'll be blinding people.
Limey is offline
Old 12-03-2005, 03:32 PM
Limey's Avatar
Also it's worth considering putting HID;s in them, they are projectors after all.
Come Jan I'm sticking 9006 hids in the IS fogs, nothing like spending $400 on a set of fog lights... ho hum.
Limey is offline
Old 12-03-2005, 06:35 PM
jasonbegin's Avatar
the pics are really blurry, so i cant really tell what it looks like, lol Sorry yo
Old 12-03-2005, 10:16 PM
Chombi's Avatar
If you want flamethrower performance lights, you do not get fogs. Get driving lights.
Driving lamps will give you a brighter more intense pattern, becuase they are meant to illuminate a narrower and farther pattern down the road. Fogs usually have hoods on their bulbs to create a cutoff that will not be as far as the ones with driving lights and patterned lenses that widens the beam. This results in a "look" that will not be as bright as driving lamps fron the front, looking at the car with the lights on.
Chombi
05 FM tC
Chombi is offline
Old 12-03-2005, 10:50 PM
Limey's Avatar
^ Yup, good fogs will illuminate 180deg arc in front of the car, only 6" high and only extending out 20-30' in front.
That's the best design from cutting under fog and lighting the road.
Limey is offline
Old 12-04-2005, 12:55 AM
DelMarVa
yes i have a 180 degree arc, just making sure that it was correct i like the look they are giving me!
Old 12-04-2005, 01:49 AM
krdshrk's Avatar
Which Hella Fog lights did you put in? I'm wondering about doing some for myself, but I don't want the OEM's. Been shopping around.
krdshrk is offline
Old 12-04-2005, 02:05 AM
DelMarVa
H3 bulb, 55amp hella they look pretty mean man... all i can say is have fun mounting them ... took me forever to measure and get them aimed correctly.... good luck.. just remember measure thrice drill once...
Quick Reply: TC Projector Fog lights installed.
