Tire Inflation Reset Button
I rotated my tires today and I noticed that my tire pressure light suddenly came on. I went to the gas station to put air into my tires and saw that the pressure lights were still on. So I decided to read the manual and it said that once I filled up the tires with air, I need to press the tire pressure reset button. Does anyone know where it is??
Kiss it first... j/k. Hmm That's weird. Your tire pressure sensor works off your abs... it should've calibrated itself. Did you drive around for 10 minutes and the light came back on or did you wait 10-15 minutes then the light just came back on?
Originally Posted by llgotscionll
I pressed the reset button inside the glove box and the light goes away. Then 15 minutes later, it comes back on. What is wrong with my tC??
IF you have the standard 215/45ZR17 tires, you're setting the pressure too high, they should be inflated to...
Front - 32psi (31.9psi to be precise)
Rear - 29psi
1) Adjust tire pressure as indicated above.
2) Turn ignition switch ON. If the tire pressure light comes on, press the reset switch (in glovebox) and release it.
3) Press and hold the tire pressure reset switch until the low tire pressure warning light blinks three times.
4) (Re)Initialization is completed after driving on smooth, dry, straight roads at a speed of 19mph to 62mph for an hour. (Max two people in car, including driver)
Rear - 29psi
Originally Posted by DouBLeJ16
I rotated my tires yesterday and the light never even came on. kind of weird.
I don't understand how it works if nothing is actually connected to the rim or tire.
Rear - 29psi
Rear - 29psi
