Is this true? (first oil change)
#41
Music City Scions
Originally Posted by WishIWasRiding
Since there seems to be some people watching this topic, I got an off the topic question. This is my first NEW car, when is it safe to beat on the clutch? Launch hard, shift hard etc? Should I treat it like a new aftermarket clutch? Does the stock need more time? Less time?
#42
Toyota says 5000 miles, but most people recommend it at 3,000 miles (even the dealership here). So I just go ahead and change it at 2500 miles. Can’t hurt to change it well before it is due?
I’m only just above 10,000 miles and I have only personally changed my oil once (first 3 times I used the freebies). When I drained the oil it looked like new, and felt just the same. Maybe I’m wasting a few hundred bucks in the lifetime of my vehicle. But I don’t really give a crap since I know that the oil in my engine at any given time is as good as new.
On the subject of oil, anyone recommend a particular synthetic? (trying to cut back on foreign oil dependency… haha…)
#43
Music City Scions
#44
lol ok.. so im going to assume that the it's ok for the first oil change to be done at 5k miles. On top of that, after I got my car and went over 1,000 miles, i sorta ran it hard right after and still run it hard often at times. My RPM went up to like 6 without changing my oil. Is this ok?
#45
Music City Scions
You know what they say about assuming stuff. Read my posts from page 1 and if you honestly think it's still "safe" go for it! It's not my car! LOL
Fram filters may suck but their old saying is so true. "You can pay me now or you can pay me later". I'll pay for mine (new engine) way later.
#47
The toyota dealership I bought my TC at gives me free oil changes for life....I get it done every 3500 miles.....My friend has a 91 toyota truck.....he gets the oil change done every 3500 miles.....the truck now has 280,000 miles on it and still runs like it's brand new.
#48
Change your own oil. Just remember that the first oil filter (the one that came with the tC) is factory sealed and needs a special tool to take it off.
Tried to take off a friend's '07 oil filter today but we had much trouble. Found out later at Jiffy Lube about the factory sealed oil filter. After that you can do your own with ease.
#50
^^I have no clue dude. We both had so much trouble trying to get it off and it wouldn't even bulge!!
The technician at Jiffy Lube said there would have been no way to take it off without the equipment.
#57
I went to the dealer to change my oil once it hit 1,100 miles. Its already on 4.5k and i'm kind of worried about driving around until I get another oil change. and I check this thread, and some of you guys change your oil at 5k? Maybe I just worry to much. My dad always changed his oil on his old celica every 3k miles and it lasted a little under half a million miles. but yeah, it is your car, so power to you guys.
#59
It's just different opinions on things. Research for yourself and make an informed decision, then realize some of it is ALWAYS going to simply be personal preference.
I have friends who still run older versions of software because "it's more stable and less likely to crash", which is true to a degree, however it's also not nearly as fast or efficient as the newer versions. *shrugs* Neither of us is right or wrong per se, it's what works for you.
Again though, I'm not saying to be lazy, or to guess, I'm saying do your research and make an informed decision that works for you. I for one remember what it was like not having the resources I do now and yes, even something as little as an oil change more often than I absolutely had to was a detriment in /my/ situation.
#60
Really the 3k is just one of those leftover from the old days kinda things. New oil (any kind) is much better than the stuff they used years ago. It wont break down as fast and your engine is built to much higher tolerances. All this means is that your oil will last longer and will have less metal and stuff floating around in there. If you are that worried go outside and take a look at it. If its free of stuff floating aeound and still looks clean you should be good. If you drive a lot of dirt roads or short drives without the car fulling warming up then change it more often as thats harder on the car and oil.
