what kind of bypass for TC '07
my Scion TC '07 and i'm looking for the bypass module. but i don't know which module i have to get,
anyone got the alarm and starter yet? so what is ur bypass module's number ?
is that the bypass module 556UW for TC '07?
Originally Posted by calvinlu85
so, i should get it online though.....
but do u know where i can het the cheap one
The key has a built in rf emitter that is picked up by a reciever at the key cylinder. To remote start a car, the car needs to see that rf signal at the cylinder, so you have to mount a key in a remote bypass box and place an antenna ring around the key cylinder under the shroud in order to "trick" the car into thinking there is a key in the ignition for remote start. You would need a 556U, if you need one still I can sell you one for $35 shipped. I'm an MECP certified installer. Thanks.
I'm fairly certain the 06 adn 07 info is the same.
DIRECTWIRE™ WIRING INFORMATION - SCION / TC / 2006 / Remote Start
12volts red (30A), white (25A) + ignition harness
Starter black + ignition harness
Second Starter green + ignition harness
Ignition blue + ignition harness
Second Ignition yellow + ignition harness
Third Ignition N/A
Accessory gray + ignition harness
Second Accessory N/A
Keysense black - ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock green to blue - driver kick, 20 pin plug, pin 15
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock purple to pink (double pulse) - driver kick, 20 pin plug, pin 14
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is purple to lt. green (-) in the passenger kick, 10 pin plug, pin 7.
Lock Motor blue to brown 5wi driver kick, gray 7 pin plug, pin 6
Unlock Motor pink to blue 5wi driver kick, gray 7 pin plug, pin 5
Parking Lights+ brown + top of fuse box, 30 pin plug, pin 29
Parking Lights- brown - headlight switch
Hazards orange - hazard light switch
Turn Signal(L) yellow + top of fuse box, 30 pin plug, pin 27
Turn Signal(R) green + top of fuse box, 30 pin plug, pin 28
Reverse Light pink + top of fuse box, 14 pin plug, pin 2
Door Trigger orange (D), blue (P) - top of fuse box
Notes: The driver door is orange in a 30 pin plug, pin 21. The passenger door is blue in a 16 pin plug, pin 14. Use both wires and diode isolate each.
Dome Supervision blue - L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin purple - top of fuse box, 30 pin plug, pin 7
Hood Pin N/A
Trunk/Hatch Release orange - driver kick, gry 12 pin plug, pin 12
Notes: Meter this wire while using the back door opener switch on the hatch.
The hatch release motor wire is lt. green to white in the driver kick, gray 12 pin plug, pin 6.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black ac data link conn. under dash, pin 9
Notes: The tach wire is also found at the ECM behind the glove box, top plug, pin 5.
Wait to start N/A
Brake Wire blue + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Third Ignition N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
Originally Posted by Espeed
I'm confused I have a 2007 scion tc, and the alarm button is on the key?
hate to say this but i wouldnt share this kind of info to anyone......you never know who is lurkin on internet forums, this guy could be a car thief (sorry dude...but no one knows) if they need info on how to bypass alarms or getting "extra" keys maybe they should try there luck @ the dealership
That's why I have a camera mounted in the back seat that feeds video through the internet. If someone steals my car, I'm going to see everything they did and where they went before they broke the camera, or found the computer in the car.
Yes, it comes with the manual. There is no difference in the U vs. UW. The "w" stands for white box as opposed to a blister pack, which is what I have to offer.
gyrotech
Scion tC 2G Aero & Exterior
10-04-2015 11:03 PM
