What to use to clean off emblem adhesive.
Old 05-29-2008, 10:11 PM
Joyride's Avatar
Default What to use to clean off emblem adhesive.
I just took off my tC emblem in the back. It left alot of the adhesive on the trunk. What can i use to take it off without damaging the paint.
I was thinking of Goo-Gone but i dont know if that is safe on paint.
What should i use? Thanks.
Joyride is offline
Old 05-29-2008, 10:13 PM
Cupcake's Avatar
I was going to say goo-gone but I also dunno about the paint. I just used some regular car wash soap and a bug/tar sponge and a lil rubbing at it all came off. I think the key thing is the sponge.
Cupcake is offline
Old 05-29-2008, 10:27 PM
Hyghgynx's Avatar
Goo-Gone FTW!! It will be ok on the paint as long as you don't leave it on there.
Wipe off the excess and then wax the spot where the tC emblem was. That's it.
Hyghgynx is offline
Old 05-29-2008, 10:42 PM
TylerC08's Avatar
Did you use a hair dryer? When I took mine off it left a very very tiny amount that came off with soap and pressure washer.
TylerC08 is offline
Old 05-29-2008, 10:47 PM
paulky_2000's Avatar
This is so simple it's scary.
Just rub your FINGER firmly back and forth ofer the area. when the bulk of the adhesive has fallen away in little "boogers", simply treat the area with a good cleaner-wax like Meguiers.
DONE
Takes like 5 minutes
paulky_2000 is offline
Old 05-29-2008, 10:58 PM
Joyride's Avatar
Thanks going to try that now since my car is dry after my wash about now.
Joyride is offline
rlo
rlo's Avatar
Goo gone and elbow grease....
rlo is offline
Old 05-29-2008, 11:03 PM
eMan40's Avatar
DONE
This method works! i used it to remove the glue/tape left over from my AVS window vents and my tC emblem.
eMan40 is offline
Old 05-29-2008, 11:06 PM
optional's Avatar
tC2 has this awesome wax/adhesive removal 3M spray stuff, that ____ totally removed all the stuff from my tint without any trouble, i imagine the goop from the emblem would be no match for this stuff.
optional is offline
Old 05-29-2008, 11:13 PM
tcbabe's Avatar
i just used goo gone, waited a few minutes, and just rubbed w/ my finger...came right off...you just have to be careful not to use your nail though.
tcbabe is offline
Old 05-29-2008, 11:28 PM
car_ram_rod's Avatar
haha i did this last night...took a blow dryer and went back and forth on low for about a minute...rubbed it off with my finger and waxed it...Done
car_ram_rod is offline
Old 05-29-2008, 11:36 PM
dave2610's Avatar
goo gone
dave2610 is offline
Old 05-29-2008, 11:49 PM
tC2_thumper's Avatar
Originally Posted by optional
tC2 has this awesome wax/adhesive removal 3M spray stuff, that poop totally removed all the stuff from my tint without any trouble, i imagine the goop from the emblem would be no match for this stuff.
yep its true, 3M wax and adhesive remover. stuff is amazing, do what they said about rubbing off what you can with your fingers then use some of this. i got it for like 8$ at shucks, could get at any auto store
tC2_thumper is offline
Old 05-29-2008, 11:53 PM
Administrator
Administrator
MR_LUV's Avatar
x5
I also used Goo Gone. Go over with a soft rag to remove excess
and I finished it off with a little carnuba wax.
I guess if you were in a pinch, you can probably roll off the 'boogers'
with your finger. If it's good enough for you nose, it's good enough
for your car.
MR LUV
MR_LUV is offline
Old 05-29-2008, 11:57 PM
kentuc's Avatar
WD-40 works also.
kentuc is offline
Old 05-29-2008, 11:59 PM
Originally Posted by MR_LUV
x5
for your car.
MR LUV
nay, i treat my tC with more respect then i do my nose.
Old 05-30-2008, 12:00 AM
krazyscion's Avatar
goo gone is awesome!
krazyscion is offline
Old 05-30-2008, 12:07 AM
BE careful putting chemicals on your paint.....
Old 05-30-2008, 12:26 AM
Aroddalobster's Avatar
i used googone, then polished and waxed. looked like new.
Aroddalobster is offline
Old 05-30-2008, 12:29 AM
I used goo gone too, but it went very fast when i added some heat with a blow dryer
Quick Reply: What to use to clean off emblem adhesive.
