When to use gas treatment?
another gas topic....i put that gas treatment in my older cars, but was wondering, when/if I should use it in the tC? I'm almost at 6000 miles...and was thinking of putting it in, so the car has no chance of buildup ? good or bad idea you think?
i wouldnt be adding additives to your car. the only thing i might consider is a fuel injector cleaner every oil chang and that is it. there might be a higher chance of build up because we can use a low octane gas but that would be for the only reason. also when you get an oil change never ever do the "engine oil cleaner" you will know what i mean when you get an oil change the cleaner strips the oil left over in your cylinders when you change your oi; so naturally when you start your car after the change the pistons will be rubbing against metal with out any oil for a few seconds plus any left over oil cleaner will change the vescosity of your oil
BlingSlade
11-20-2015 07:56 PM
JymmyTheSaint
08-26-2015 04:44 PM
