Why vary engine RPM?
I know somethings about cars and how they run, but I don't understand any at why you should vary the engine's RPM speed at first breaking it in...
Can anyone explain this in lamens terms please?
:oops:
:oops:
your supposed to vary speeds to make sure seals and rings seat well before you go whippn around, thats all i know not sure on technical things but im sure that website that tells u how things work would have the answer
Music City Scions
Because while the engine is running the loads on the parts that touch vary depending on the speed. The higher the RPM the greater the load. If it was an engine that ran at a constant RPM all the time like say a lawn mower or generator for the most part it would not be so critical. By varying the RPM it evens out the wear patterns. correct me if I'm wrong
so wouldn't it be good to have spirited acceleration every so often? not hard just firm... like a good smack when ya tap dat ___ sorry to the older mature crowd, gettn tired and nutty
Bakoscion46x
01-19-2015 02:39 AM
cid_mcdp
01-05-2015 02:45 PM
