07 TC tire wear
07 TC tire wear
Hello, The tires on my stock TC are wearing in a choppy pattern only on the very inside row of treads. They have been rotated a couple of times and the car has 17K on it. I took it to the dealer for an alignment check and they said everything was within spec. i have the printout with the numbers on it if that helps. Anybody else having this problem? The tires are very noisy at low speeds.
Thanks
Thanks
If everything's within spec, then it's likely that the tires are just worn out and need replacing.
The tires supplied with the car are not very good, and are largely responsible for the mediocre handling ratings given by independent testers.
Time to replace them... but search for recommendations, and choose a tire based on what you'll be using it for.
All-seasons with high treadwear for just daily road use.
Soft, sticky tires with low treadwear ratings for racing.
One other question - Do you usually keep a lot of weight in the car? Keeping a lot of weight may cause temporary excessive negative camber, which goes with what you're describing.
also alot of it comes down to where you drive, and how you drive.
my stock ones (the bridgestone protenzas) lasted only about 20K before i had to replace them...my mom's subaru which has the exact same set that my tc came with, and she is at nearly 60 k, and they are still fine.
granted, there are different cars, with different suspension and drivetrains, but i think it is largely due to her driving much more slowly then i do.
I hardly ever carry extra weight in the car and if i do it's only for a very short time. I hate to replace the tires as they have alot of tread left on them. I would hate to replace them and have the same problem again. The stock tires are yokohamas, what do you recommend for an all season tire. Here in wisconsin I have to have a tire like that.
thanks
thanks
Re: 07 TC tire wear
Thanks
Thanks
thanks
thanks
Also if you do need new tires, I'd recommend (along with a lot of other tC owners) the Toyo Proxes4 very good indeed, you can do a search to see what everyone is saying about them. Good match for the tC.
i have this problem too. its called "feathering" my co workers (firestone technitions) are telling me that its because of constant acceleration so i dono. they like to feed me as much BS as they can. try some new tires
George
01-11-2004 10:13 PM
