adjustable coils less for 500$
Old 07-30-2008 | 12:45 AM
da1nonlytc08's Avatar
DelMarVa
Default adjustable coils less for 500$
does anyone know where i can get adjustable coils less then 500 i looked everywhere and too much for and plus i need it because i just put a body kit on mine and its so high off the ground
Old 07-30-2008 | 12:52 AM
808tC's Avatar
ground control is the higher end = $430
questionable( but have bad reviews) > m2 coilovers = $200
questionable (mixed reviews) > any celica colovers = $50 - $300
Old 07-30-2008 | 01:43 AM
Chrisb319's Avatar
get quality coil overs don't get junk anyone coil overs bought for 50 dollars have to be cracker jack quality stuff.
250 dollars more you can ****** Tein Basics for around 750 I think.
stay away from sleeves.
Old 07-30-2008 | 01:57 AM
etoomey3's Avatar
EBAY!!! just keep looking and waiting, I got my Function and For Type 2 Coilovers for $560 second hand, nothing wrong w/them, just have to be in the right place at the right time
Old 07-30-2008 | 03:26 AM
engifineer's Avatar
My guess since you have a body kit is that precise handling and performance is not what you are aiming for. All you want is lowering. In that case, coilovers are a waste of your money, just get lowering springs. Coilovers are for corner balancing, setting the optimum ride height for handling (which is about 1.4 inches lower than stock.. you can get that from various lowering springs) and tuning the suspension characteristics. Outside of that, they are of no value.
Just find some good springs at the height you want and save yourself some money.
And if and when I switch to coilovers, hopefully next year, so I can tune and cornerbalance, I will be going for Tein SS-P's at least. You get what you pay for with suspension parts. While a "cheap" set of coilovers may seem fine under normal driving, they will be sub-par when you start trying to really squeeze the handling out of the car.
Old 07-30-2008 | 03:33 AM
davedavetC's Avatar
dave where can you go to Corner Balence and do they adjust teh dampening when they do it too?
Old 07-30-2008 | 03:50 AM
engifineer's Avatar
Suspension/alignment shop. When I make the switch I will be going to my alignment guy, whom does a lot of race setups.
To corner balance, they will set the car on a set of scales and adjust until the cross weights are as close to equal as possible. The same shop should be able to help you set the damping as well, although they may not know exactly what you need for your application. I know some autox'rs have called koni and asked their advice given the type of car and what you are trying to do with it. Koni will also make you the custom valved dampers if you want to spend the money
Most people I know just take it to a test n tune and start playing with the damping between runs. However, I know some setups are hard to get to and adjust on the fly like that.
Old 07-30-2008 | 09:48 PM
davedavetC's Avatar
i wonder if i can get heavy duty scales and corner balence myself haha
Old 07-30-2008 | 10:16 PM
engifineer's Avatar
Hey.. how cool would it be to have a 4 wheel scale set in your garage :D
Old 07-30-2008 | 10:29 PM
davedavetC's Avatar
pretty sweet
yupinmytC
22
07-27-2024 07:08 PM
That_Kid_Ju
09-30-2015 10:05 PM
Luna7ic
09-28-2015 03:30 PM
Darrenohooligan
09-26-2015 07:21 AM
Topfueltom69
09-06-2015 05:25 PM
Quick Reply: adjustable coils less for 500$
