B + G rs2 coilovers?
Hey, Does anyone know how to lower the rear coilovers? I've raised the spring perch all the way and raised the lower mount all the way up, and then dropped back down the spring perch to a 1 wedge gap between the lower mount and the spring perch. It's still a finger gap. Help please!
There is a perch up top where the spring sits, as well as an additional collar at the bottom where the entire shock body goes into. This additional collar is threaded and allows you to lower the ENTIRE SHOCK BODY without messing with the spring and perch at the top.
![](https://i202.photobucket.com/albums/aa46/bJkuhl/BG-Adjustability.jpg)
Where it says 'threaded collar' is where you're making your height adjustments. Visualize this: you adjust the height by using the collar on the body of the shock. The spring perch has not been adjusted. The shock travel has not been adjusted. The shock travel is the same, so its no closer to the bump stop than it was in the first place.
lowering the perch just adjusts the tension of the spring. The only adjustment for ride height should have been then threaded collar at the base of the strut. I guess the only thing left to do if that didn't work is to contact B&G. Ride Height Adjustment should have been as simple as what I stated above.
which ever you can get for cheaper. both are of good quality and ride. like someone else said here, jordan from socal tc club is selling his set of coilovers. i know he got them last november and has to sell due to a new baby in the house.
Darrenohooligan
09-26-2015 07:21 AM
rmz489
09-16-2015 08:19 PM
