Best/cheapest place for replacement struts
Old 10-13-2009 | 08:45 PM
tcd2004's Avatar
Default Best/cheapest place for replacement struts
The rear struts on my girlfriends 2005 tc are getting noisy so I'm starting to look into replacement options. Last time I checked autozone, they weren't able to get replacements yet since it was a newer car. I'm just looking for an OEM/OEM equivalent, doesn't have to be anything that's higher performance. Where is my best option to buy them from and what can i expect cost wise for just the parts? Thanks for the help
Old 10-13-2009 | 10:29 PM
DJ08tC's Avatar
Check trdsparks.com under there oem replacement parts. I think the last time I looked they were like $100 for each side for the front and for the rear for the actual strut body it is like 95
Old 10-13-2009 | 10:30 PM
asthmatic's Avatar
Best place to get OEM cheap is from the classified section and try to find someone selling them used. I have my oem struts with a 1000 miles on them if you're in souther california. ;)
^TRDsparks is cheaper than local dealerships.
Old 10-14-2009 | 12:07 AM
tcd2004's Avatar
So would it be number 1 in this picture ?
Unfortunately I'm not in any part of California. Would you be willing to ship them to Michigan?
Old 10-14-2009 | 12:08 AM
DJ08tC's Avatar
Yea, as long as all the other stuff is fine you can just transfer it over.
Old 10-14-2009 | 12:11 AM
tcd2004's Avatar
If it's noisy over bumps, when the suspension travels up and down, isn't the strut the main culprit?
Old 10-14-2009 | 12:15 AM
DJ08tC's Avatar
Yea, that could be it. It also could possible be the rear sway bar bushings, they might to be regreased.
Old 10-14-2009 | 12:22 AM
hydralover's Avatar
Yes, that's part number 1. The rest of the stuff is basically cushion for the spring and holds it in place. You should be able to re-use them without fear.
Old 03-23-2010 | 01:59 AM
tcd2004's Avatar
Couple more questions. Are the left and the right side the same part number? Also, do all model years of the tc use the same part number?
tato63
Scion tC 2G Wheel & Tire
9
09-30-2015 09:55 PM
Scionxa180
07-11-2015 10:50 PM
Renike
03-01-2015 10:40 PM
torranosaurus
01-28-2015 04:53 AM
hampton1100
01-02-2015 08:13 PM
Quick Reply: Best/cheapest place for replacement struts
