Brake Line Fitting Size
Old 06-23-2011 | 05:24 PM
johnhawkins's Avatar
Default Brake Line Fitting Size
Can someone tell me the brake line fitting size? I have the correct tube size but was given the wrong fitting size. I looked in the tech section but was un successful at finding a size?!?
I am refering to the brake line flare nut.
Old 06-23-2011 | 09:00 PM
Ace83's Avatar
Ronin Scion
are you referring to the threads or the size wrench to use?
Old 06-24-2011 | 05:30 PM
The thread or nut size
Old 06-25-2011 | 02:29 AM
gtfourtc's Avatar
the caliper side or the thread fitting on the line that screws into the caliper is metric m10x1. Hope that is what you are looking for
Old 06-27-2011 | 06:48 PM
Old 06-27-2011 | 09:54 PM
gtfourtc's Avatar
I am pretty sure the brake line fittings on all the hard lines have the same 10x1mm metric thread. I know that is what the fitting on the hard lines going into the master cylinder, so ot makes sense that all the hard lines would be the same
Old 06-27-2011 | 10:37 PM
Thanks for the help - I asked this question before and I bought what was suggested and its just a little too big (found out after flaring and bending a line and the bolt didnt fit lol) thanks for the help Ill try and confirm once i order them and try
Klutch_Wheels
Scion tC 2G Wheel & Tire
12-31-2014 06:16 PM
Quick Reply: Brake Line Fitting Size
