Brake Pedal Making Clicking Noises & Feels Loose
Originally Posted by jerry2334
I'm interested to hear how this went, since I guess I'll be doing mine myself too. Stupid dealers.
How much was the new switch?
List price is $32.24, trdsparks is selling it for $25.79 so think around $30 from your local dealer.
Those of you that changed your brake light switch, did you just hear the clicking or did u feel the clicking in the brake pedal as well? I don't just hear the clicking noise though I feel it coming from the pedal area. It doesn't happen everytime I step on the brakes but I would say about 60-70% of the time.
Those of you with clicking when you step on the brakes, did the clicking occur when you stepped on the brake and then again when you let your foot off the pedal? I hear a clicking noise when I step on the pedal and again when I release the pedal.
Help is appreciated. Thank you in advance.
This clicking that is caused from the brake light switch occurs even when your brake lights are still working?
Maybe something is loose with my pedal. Can your brake pedal actually get loose and cause a clicking/clunking noise when pressed?
The play in the pedal is also causing some noise when the brake pad is stepped on. It just feels very sloppy.
Could me needing rear brakes soon cause any of these issues? (I obviously don't know too much mechanical stuff about cars)
I am bringing the car in to the dealership for an oil change and tire rotation either end of this week or beginning of next so I will probably get my rear brakes done at the same time.
clicking in the pedal wouldn't be because you need rear brakes. since the clicking is coming from inside the car not outside. its cool if you dont know mechanical stuff that's what forums are for, to ask questions.
oh and yes to your question about the brake lights. Mine were working as well but the plunger that's part of the brake light switch was binding causing the clicking. hope that helps.
well i know that when the switch went bad it did make the pedal feel like there was play in it. It was the switch itself moving around where it was mounted plus the clicking was from the switch going bad and sticking. that was where my clicking was coming from. you should get someone to stick their head down there while you push on the brakes and let them locate the noise or you have someone push on the pedal and you can listen.. either way to be able to locate the noise.
evolving_machine
10-21-2023 01:16 PM
fur_pig
12-05-2014 12:48 PM
