C Pillar Bar. Keep your back seats!!! (updated 9/29)
Updated 9/29/05
I found a way to keep the back seats with a C pillar, without hitting rear passenger heads.
I used Megan Racing C Pillar bars for 94-01 Integras (will be referred as the "Short-Bar") and 90-93 Integras (will be referred as the "Long-Bar").
You must remove the trim panel around the rear upper seat belt mount (1 panel per side) to mount any of these bars. You can try to modify the panels, but I chose not to. Pull them off (if youre smart, you can figure it out yourself).
Once removed there are 6 possible mounting points for a bar.
Points A & B have existing bolts that attach the interior panels to the car.
Point D is the rear upper seat belt mount.
Points C, E, & F are reinforced threaded holes, but they do not have a bolt in them. Its the same size as the holes from points A & B. I bought some longer versions of these 10mm (dont know the pitch) bolts at the hardware store.
A Short-Bar can go across points A, B, C, & E. The bracket on point B will not work with the bar, so you may have to remove it if you use that pont. To use point F, you'll need a bar thats 2-3 inches shorter than the Short-Bar. Point D will require a Long-Bar.
As you can see Point C mounts at the back of the rear head rests. That photo was taken behind the car, so the angle makes the bar look like its positioned further foward than it really is.
X Mount
Dual C pillar Z mount
X Mount
passengers? thats that? lol. the only reason I keep my back seats is because it makes the trunk look cleaner when theyre folded down. lol. I plan on replacing the end bolts with lock pins to make the bar a quick-release.
strut bars, lower arm bars, pillar bars, sway bars are more for show than performance. largely ineffective unless you combine all those bars with springs/shocks and tire upgrades. perhaps the bar made my car 2-3% stiffer overall, similar to a 3% power increase an intake adds. hardly noticable. if i really want to stiffen up the ride, i'd adjust my coilovers to a stiffer setting. lol.
Originally Posted by midnight_runner
i think all megan bars are the same, just the length of the bar is differeant to accomodate the differant lengths. I wouldn't be surprised if all Megan did was find an existing one that already fit and called it a TC bar
goto megaracing.com and see their bars. some are used across different vehicles.
i'll be so jealous if Megan makes a longer one for the TC. The integra bar I'm using is 45 inches. I can see it vibrate alittle as I drove over small road bumps, but I suppose any bar of that length would move alittle.
Will they measure chassis stiffness before and after the bar to show how it does something or is this just a bling mod?
BTW, when I was designing and building motorcycle chassis mods we used a pretty simple rule of thumb to test any design. Imagine a pin that allows free movement of anything you add to the chassis holding the new piece in place at both ends. Apply force from any direction. If the new piece allows movement, go back to the drawing board, you didn't get it right.
If you added a cross brace from the opposite sides of that strut tower, that would seriously add some resistance to chassis flex. The bar now only seems to keep the rear seat belt mounts a specified distance apart. Is that the goal?
check the link for a techinical explanation for the validity of these bars.
give them an earful if you think its all a bunch of crap.
i'm just copying their design with megan bars (because EMracing only does hondas).
http://www.emracing.com/formula.html
And if you really wanted to get exotic, you'd take two sheets of CF/Kevlar co-weave and slap them on either side of a 1" thick 0.020" aluminum honeycomb and bolt to to the C pillar mounts and the tops of the rear shock tower support bar. Even better than triangulation, and super light to boot. But I digress...
