camber issues
Old 08-07-2006 | 11:01 AM
Slammed-TC's Avatar
Default camber issues
hey guys i was wondering if anyone has the eibach sprortline springs. i have had them installed for about 5k miles and notice that the rear camber is really noticeable (negative). have any of u S Tech owners had this problem? should i get a camber kit? was something installed wrong? please help.....
Old 08-07-2006 | 11:09 AM
BigMURR's Avatar
I would say that if the drop is more 1.75" you must get one, but you should get the kit for any drop to counter the change in camber.
Old 08-07-2006 | 05:07 PM
tcengel's Avatar
They are not needed really. Did you get an alignment???
Old 08-07-2006 | 05:23 PM
BigMURR's Avatar
well yeah they aren't needed but if you want to buy new tires constantly because they keep wearing out then yes you might want to get the camber kit, just my .02
Old 08-07-2006 | 05:48 PM
tcengel's Avatar
There is enough adjustment stock to get them back to "within Spec" so no you do not need them. Only way you need them is if you want extra adjustability for a race alignment. Since he hasn't gotten an alignment yet I would say that it's highly unlikely he will be setting up for racing any time soon.
Just go get a good alignment.
Old 08-08-2006 | 12:14 AM
Slammed-TC's Avatar
thanks everybody....i really appreciate ur input. since the springs install i havent got an alignment. will i have any trouble bringing in a lowered car to get an alignment? i have read that some wheel shops will not do it.
Old 08-08-2006 | 01:10 AM
BigMURR's Avatar
that is true, but just search around and you'll find one.
I wouldn't go deal____ they charge tooo much.
tcehgel - if what you said is true, thanks for the info. I know much about hondas but am still a little new with scions.
Old 08-08-2006 | 02:42 AM
Yanki01's Avatar
i have some camber but not much! Looks good, had my Hotchkis drop for about 10 months! Tires still look good!
Old 08-08-2006 | 04:09 PM
jonnyHKboi's Avatar
just get an alignment and it will be back to factory specs. the eibach drop is not as big as the s-techs and the alignment got my wheels stright again with the s-techs.
Old 08-16-2006 | 02:41 PM
BOXMAN's Avatar
Go to www.ingallseng.com You can dial your tc back to factory spec for about 25-50 bucks plus alignment. Also check out the other items offered by ingalls if you are serious about suspension for your Scion
Old 08-16-2006 | 07:08 PM
Mr_Meaty's Avatar
I put on my Hotchkis springs and noticed a little more negative camber then with my TRDs before an allignment.
My car was in the shop for some bumper damage, and I talked them into giving me an allignment for free.
They said they couldn't do much cause it was lowered, but they got just about all the rear camber dialed out! It's straiter then it was with the TRDs! But I'm not sure if the dealership did an allignment after putting the TRDs in.
Old 08-16-2006 | 07:26 PM
BOXMAN's Avatar
^^^www.ingallseng.com^^^ is your answer we have kits to help dial that front back into spec. If you need help once you find a part I can direct you to one of our fine vendors on scionlife. Thanks
Old 08-16-2006 | 08:04 PM
2fast4you's Avatar
Team ScionTific
I ordered a set of camber bolts from Toyota for $11. It did the job for me with a -1.75 front drop.
Old 08-16-2006 | 08:12 PM
brownfield's Avatar
i have the hotchkis set... i never put it on since i got put on orders to alaska the week i got them in... if anyone wants to buy them off me for cheap ($75) pm me...
Old 08-16-2006 | 08:56 PM
tc-guy's Avatar
hey slammedtc, if a 30 min drive to south sac is not that far for u, autobahn performance can do a four wheel alignment on ur tc for like $65. he specializes in aligning lowered cars. he did my tc when i got my s-techs put in wif no problems. my cars alignment is back to stock wif a 2 in drop all around.
Old 08-22-2006 | 04:30 PM
jbae1221's Avatar
i took my car to get aligned and they said the rear chamber is not adjustable.. so now i'm thinking that it is.. which is true
Old 08-22-2006 | 06:54 PM
2fast4you's Avatar
Team ScionTific
The rear camber is adjustable. The shop I took my car to tried to pull that same BS until I pulled out the Toyota alignment instructions and shoved them in their face.
Old 08-22-2006 | 09:37 PM
BOXMAN's Avatar
Tell your allignment shop to look at www.ingallseng.com or hotchkis or toyota. These parts are made to get your Tc back into spec.
Old 08-23-2006 | 12:13 AM
StickS707's Avatar
Dang it...I wish I would have hit this thread yesterday..I just ordered the Hotchkis TVS stage 1 (springs and both sway bars) last night . I woulda taken those off your hands had I known
Old 08-23-2006 | 10:38 PM
jbae1221's Avatar
now.. how much can the rear chamber be adjusted
Quick Reply: camber issues
