Coilovers... the proper way.
I've said many times before-- you can't just buy these things and slap 'em on the car. Like anything else, setup is more critical than the parts themselves. Luckily, I have excellent parts, and access to even better setup equipment.
So a couple of pics of the tuning of my new Tein SS-P w/ EDFC, thanks to my racecar-driving brother-in-law, a Longacre chassis scale, and a milkcrate full of lead bars.
I think I had to take off and put back on each tire about 20 times. Not fun.
![](https://img.photobucket.com/albums/v307/DrIsotope/install01.jpg)
It's not a proper alignment unless the driver's weight is in the seat...
![](https://img.photobucket.com/albums/v307/DrIsotope/install05.jpg)
The front end was a bit of a bear. We chased a few pounds of crossweight for about an hour, moving tenths of a percent from corner to corner until we got it right.
![](https://img.photobucket.com/albums/v307/DrIsotope/install04.jpg)
Where we finally ended up, after zeroing the swaybars (the rear came out fine, the fronts required me to build new links)
![](https://img.photobucket.com/albums/v307/DrIsotope/install03.jpg)
Total weight, including full fluids, audio, weight of driver,
3301lbs.
Leftside weight: 51.4%
Rear weight: 41.7%
Cross weight: 50.0% (we got a good laugh at the rear weights being 711/666)
Camber: -1º all the way around.
Front drop: 1.6"
Rear drop: 1.2"
New house for the EDFC:
![Icon Tongue](https://www.scionlife.com/forums/images/smilies/icon_tongue.gif)
3301lbs.
Rear weight: 41.7%
Front drop: 1.6"
Rear drop: 1.2"
![](https://img.photobucket.com/albums/v307/DrIsotope/EDFC.jpg)
Thats the only way to do it. If they arent going to be tuned, coilovers are a waste.
Hoping to be at my alignment guys shop next spring doing the same on mine.. but I bet I am not going to get the same deal you did on the teins doc
Originally Posted by BlizZard
is that a rear camera on your bumper?
Originally Posted by curtislo9
Are the ss-p's pretty comfortable with its adjust ability?
Originally Posted by Nastos
pictures of the final drop?
Rough roads + very stiff springrates ≠ smooth and comfortable
On the freeway, it feels smoother than TRD. Rough roads feel... rough. The upside is, I scrape much less than I used to-- very short damper travel and those stiff springs see to that.
