Dan Gardner Custom Sway Bar is now available thru Dezod Motorsports
Old 05-12-2010, 06:45 PM
  #481
Scionetics
KAD
paul_dezod's Avatar
Originally Posted by oueng
How many are left Paul?
paul_dezod is offline
Old 05-13-2010, 04:48 PM
  #482
tcday's Avatar
ummmm how much for this i might be considering it since i need a sway bar
tcday is offline
Old 05-13-2010, 09:18 PM
  #483
RoboCop's Avatar
http://www.dezod.com/pd-dang25bardeposit.cfm
$220 before shipping. Shipping ranges between $20-$25. It's an awesome bar and it comes with adjustable endlinks too.
RoboCop is offline
Old 05-13-2010, 09:36 PM
  #484
tCvirus's Avatar
Originally Posted by KiKaZ-sC
sounds like the bar could be sitting on the lower control arm. make sure that your bar is not in contact with anything and if you're using this bar on the softest setting... you'll basically need to extend the adjustable endlinks all the way out.
I actually think this is the problem. There's only about less than an inch showing of the screw between the two bolts on either end of the endlinks. I was scared to have them too far apart incase they came apart. o.O
I'll mess with them later and see if the noises stop but I did notice yesterday while my friends were getting out of my backseat that the bar was noisey as hell. Also noticed last night while driving slow in a drive-thru that it was creaking really bad. Anyone else having this issue? I'm almost tempted to uninstall it and go back to stock bcz it's embarassing having this noisey car! lol
tCvirus is offline
Old 05-13-2010, 11:45 PM
  #485
RoboCop's Avatar
Mine's ultra noisy too. Never been this noisy before. Price you pay for performance.
RoboCop is offline
Old 05-13-2010, 11:49 PM
  #486
Domo's Avatar
I have yet been able to install mine. haha....sucks but yea, performance do not normally=comfort.
Domo is offline
Old 05-14-2010, 12:49 AM
  #487
GrnBrownies's Avatar
x2..love the handling but the damn bushings make noise every time i hit something on the road
gonna grease that sucker up really nice when i get the chance
GrnBrownies is offline
Old 05-14-2010, 01:22 AM
  #488
engifineer's Avatar
You are running a race bar with poly bushings. You deal with more noise and less suspension independence in trade for better handling. "Race proven" means just that.. it is tailored to track more than daily driving.
But you can minimize most of the noise. I used the lube that came with it and dont hear a peep out of it most of the time. Backing up and stopping at low speeds I hear a small amount, but it isnt bad. You will hear that more when you hit an "even" bump that affects both rear wheels together. The bar as a whole moves more in that case.
engifineer is offline
Old 05-14-2010, 02:59 AM
  #489
b52hDUNN's Avatar
Right now I have tein s techs and a trd front strut bar. The TC is my 4th car and I have never added sway bars before, so I have never felt the difference. Worth the 245 dollars for this sway bar?
b52hDUNN is offline
Old 05-14-2010, 03:23 AM
  #490
engifineer's Avatar
BIG difference in handling. Strut bar is a tiny difference on this car.. so yes, you will notice a big change.
Old 05-14-2010, 01:15 PM
  #491
tCvirus's Avatar
I had trd springs and a Ebay sturt bar, which is mainly for looks since those don't make much of a difference. I had decent handling with the springs but the sway actually made my car fun to drive. lol The best way I can describe the type of difference is going from a bicycle to a tricycle. Your turns are a bit sharper and the rear is stiffer.
tCvirus is offline
Old 05-14-2010, 01:37 PM
  #492
speedintc's Avatar
haha tcvirus i like your comparison.
speedintc is offline
Old 05-14-2010, 03:47 PM
  #493
KiKaZ-tC's Avatar
TRAINING WHEELS FTW!
KiKaZ-tC is offline
Old 05-14-2010, 04:23 PM
  #494
Scionetics
KAD
paul_dezod's Avatar
Yes. This diameter is significantly larger than that of stock and can yield dynamic differences even at softer settings.
Old 05-15-2010, 02:01 PM
  #495
tCvirus's Avatar
Actually, that would be a better comparison. lol Especially when you have training wheels that are too small so your bike wobbles side to side, usually having only one wheel touch the ground. Yeah it's more like that.
tCvirus is offline
Old 05-15-2010, 02:12 PM
  #496
rougenite's Avatar
I finally got ahold of mine as the ugy actually came by while i was home. Glad to be back in hawaii! Installing this...well before monday
rougenite is offline
Old 05-16-2010, 03:58 AM
  #497
RoboCop's Avatar
Sprayed down with lots of white lithium grease and now my car is back to being quiet...for now.
RoboCop is offline
Old 05-16-2010, 04:22 AM
  #498
tCvirus's Avatar
I will have to try this. It's getting really bad. I used half the tube on each of the bushings but I guess it's not enough. You don't think it could of gotten washed away from driving in the rain we've had do you? Maybe if the bar gets wet it could run in there somehow... I dunno. lol
tCvirus is offline
Old 05-16-2010, 05:18 AM
  #499
RoboCop's Avatar
Grease has the nice capabilities of not mixing with water, so I don't think rain will do anything. It probably just wears away in certain spots.
RoboCop is offline
Old 05-16-2010, 11:10 PM
  #500
engifineer's Avatar
Took about 25 runs or so today at a test n tune (autox). Actually, was taking it easy, just playing with the settings, or I could have easily fit in 40+ runs.
Ran the bar on the stiffest setting all day. We use 2 courses at the tnt's, usually one that is more flowing and one that has more slower technical sections. The car felt GREAT on both courses. Rotated nicely, was well balanced through the corners, stable through the slaloms, etc. Needs to be driven smoothly of course with its higher tendency to rotate , but felt great overall.
Quick Reply: Dan Gardner Custom Sway Bar is now available thru Dezod Motorsports
