Dan Gardner Custom Sway Bar is now available thru Dezod Motorsports
Old 07-09-2010, 07:08 PM
  #621
Scionetics
KAD
paul_dezod's Avatar
The three point strut is cool, but Dan brings a critical point about drilling into the firewall. Are many of you prepared to do so if this comes about?
paul_dezod is offline
Old 07-09-2010, 07:36 PM
  #622
oueng's Avatar
i am prepared to drill into the firewall and what looks like weld the mounts to the strut tower.
oueng is offline
Old 07-09-2010, 10:59 PM
  #623
tokenride86's Avatar
id be down, id like to see what the area where its mounted at the firewall looks like. and my only concern is how close the crossbar is to the motor. but it looks way more functional than any strut bar out for the tC
tokenride86 is offline
Old 07-11-2010, 12:31 AM
  #624
Domo's Avatar
I just placed the endlinks on the stuffiest setting and lubed the bushings a bit more. Actually I lube it a lot more. The bar is quite now but it seems like the lube that came with the bar isn't really durable.
Domo is offline
Old 07-11-2010, 02:52 AM
  #625
myr6goesfast's Avatar
i used anti seize
myr6goesfast is offline
Old 07-11-2010, 10:28 AM
  #626
Domo's Avatar
meh...its squeaky again. The silence only lasted for a few hours and now its back to blah. Maybe I will try some KY Jelly.
Domo is offline
Old 07-11-2010, 04:52 PM
  #627
engifineer's Avatar
Like people have already stated. These are poly bushings. They WILL squeak to some degree no matter what. Doesnt matter how good the lube is. You may get rid of most of it for a while, but you will still have some squeak. Welcome to the world of track equipment ;)
As far as the front strut tie... they do practically zero for someone driving on the street, and even autox or weekend warrior guys will see small benefits at best from it. I got my car with the hotchkis one, but wouldnt go out and spend good money on one if I didnt already have it. Now, when thousanths count in a full on competition event on a longer track, then I could see wanting it.
engifineer is offline
Old 07-11-2010, 05:32 PM
  #628
RusWolf's Avatar
^^Good point engi.
RusWolf is offline
Old 07-11-2010, 06:00 PM
  #629
ky warming? :D
Old 07-11-2010, 07:59 PM
  #630
Domo's Avatar
hows the anti-seize working for you?
Domo is offline
Old 07-11-2010, 11:48 PM
  #631
RusWolf's Avatar
How loud does it squeak, so loud that you can hear inside of the car ?
I don't even think i'll be ever to hear over my exhaust but we'll see in october.
RusWolf is offline
Old 07-12-2010, 01:44 AM
  #632
SR0529's Avatar
take out the black rubber or whatever it call. spray the white lithium grease on the bar where the black rubber sit. it should help to stop the noise. that was what I did today. I drove around and past the speed bump. no more squeaking noise.
SR0529 is offline
Old 07-12-2010, 03:20 AM
  #633
Domo's Avatar
Is your car lowered?
Domo is offline
Old 07-12-2010, 04:04 PM
  #634
SR0529's Avatar
well, I have TEIN H tech
SR0529 is offline
Old 07-12-2010, 09:24 PM
  #635
ScikoTRDtC's Avatar
so i just put the bar on i got right....did these steps
1. jacked the car up and put on stands
2. took the stock bar off
3.lubed up the bushings put those on then the brackets over on the outside of the protruding ring around the new sway
4. didnt know how to position the sway once semi tightened down onto the mounts so i just kind of aimed the arms where the endlinks connect between the upper and lower control arms?
5. jacked my two back wheels up to a point where the car wasnt lifted off the jack stands and the wheels were up as high as they could go. would that be considered a static ride height to adjust the endlinks?
6. set the endlinks on the outside and put them on the middle setting and made sure everything was straight as possible i have some pictures ill put up later to make sure i did everything right.
what do you guys think? mission accomplished or did i do a couple things wrong?
ScikoTRDtC is offline
Old 07-12-2010, 10:28 PM
  #636
Domo's Avatar
Not sure if you did step 5 right. Read a couple of post back, Gardner says, you need to sit the car on ramps in order to adjust the endlinks, otherwise your endlinks will bind.
Domo is offline
Old 07-12-2010, 10:50 PM
  #637
pinoyFMtC's Avatar
Yeah, step 5 may be incorrect. Put it on ramps or park the rear tires on the edge of the driveway/curb (with e-brake on of course and car safely parked) to make sure there is full load on the rear. And yes, looking from the rear of the car the endlinks should be vertical.
After tightening the sway all the way on the mounts, you want the sway as parallel to the ground as possible, but make sure you have enough clearance so you're not rubbing the sway on anything.
pinoyFMtC is offline
Old 07-13-2010, 01:43 AM
  #638
ScikoTRDtC's Avatar
alright well i didnt have ramps where i was adjusting them at but i do at my house so thats good.
Old 07-13-2010, 02:00 AM
  #639
Domo's Avatar
i just used bricks.
Domo is offline
Old 07-13-2010, 04:11 AM
  #640
ScikoTRDtC's Avatar
i just used bricks.
so you just lowered the car tires onto bricks so there was load on the suspension?
Quick Reply: Dan Gardner Custom Sway Bar is now available thru Dezod Motorsports
