Endless USA 4 Piston Big Brake Kit !! PICS 56k TOO BAD!!
First OFF, i want to say thank you to Eric "the Instigator" form Stoptech That took the night to help me install the big brake kit. Actually, he did the entire thing himself so thank you
This is the first Full Set from Japan for Scion tC Application. Thanks to Rishie FRom AUTO RND, he got the first set in the US to me visit www.autornd.com to check their stuff out
Here are some Pics
THERE YOU Go
Enjoy =D
Here are some Pics
THERE YOU Go
Enjoy =D
it is the stock rotor size but just lighter
so in essence, you don't need to ge tnew rotors, but if youw ant the full package, here it is.
It took eric to install it in about 2 hours. The only problem he had was taking out the stock parts.
But its pretty much a good easy swap if you know how to take apart your brakes system. Bleeding the brake lines is required as well.
Originally Posted by tcholic
Originally Posted by bubblemyster
is the caliper and pads bigger than stock?
call rishie from autornd
408-635-0000
or emaili rishie at wholesale@autornd.com he loves emails...seriously he does, he rather talk to me on email lol
408-635-0000
408-635-0000
408-635-0000
We are hesitant to produce a larger than stock rotor diameter because you will lose power on the FF cars. What we've done is produced a brake system that will function just as well but not have any of the downsides.
This is called a System kit.
Rishie
Rishie
why would i want a system that fuction just as well as stock? any numbers to back up why the endless caliper and rotors will be better than OEM? In essense, this isn't really a big brake kit, just bigger calipers.
also, when you say that it will function just as well, i assume the stopping distance won't be shorter and when you say without the downsides, you mean there is less brake fade under high temps? more details please.
