ES motor mounts/bushings install question? cost?
Old 08-21-2009 | 12:46 AM
ColonelSanders85's Avatar
Default ES motor mounts/bushings install question? cost?
Ok so I recently ordered the ES motor mounts/bushings, as well as an Ingall's ETD. I read a few different DIY's for the bushings and frankly, I don't have a vehicle lift or a steel press, so I need to find a place that will install them for me. Anyone else have this done? If so, where did you take it and how much did it cost?
Old 08-21-2009 | 02:19 AM
charlie07tc's Avatar
I did the whole job by myself with hand tools, a ball joint press, and jackstands, I used a diy from clubsciontc as reference. It was major hard work to do the front and rear mounts, the front was a nightmare to press in, that I'd take to a shop. To get the side and rear mounts removed I used a drill to tear out the rubber and a flat screwdriver to remove the metal ring. pressing the side and rear inserts into the mounts was pretty easy.
Old 08-23-2009 | 06:42 PM
ok im bumping my own post. Anyone else know where I can just pay somebody to have this done?
Old 08-25-2009 | 01:47 AM
Nobody else at all has any info?
Old 09-03-2009 | 10:10 PM
bump again?
Old 09-09-2009 | 08:26 AM
AcidDrop's Avatar
post in the your regional section and maybe someone local can help you install them or tell you which shop to take it too. a friend did mine at his shop and all went good, i used to have the ingalls ETD and both together was great, later switch the ETD to the DME because i wanted to lol.
Old 09-11-2009 | 04:30 AM
arbnpx's Avatar
I had mine installed by a shop; it took 1.5 days because he didn't want to rush through it (which I was perfectly OK with). I didn't ask how hard it was, but I gathered that there were some moments during the install. Got to rent a Camry 4-cylinder while it was being done; that made me appreciate the coilovers and bushings a lot more.
Old 09-11-2009 | 05:40 AM
davedavetC's Avatar
i did mine at school last year took about 4 hours to do all of them, the hardest was the rear, i found it easy to remove the driver front wheel, S-Pipe, Mid-Pipe and the heat shield above the S-Pipe and use a realllllly long extention and go in from the wheel.
have fun, get plenty of beers, cigarettes and anything else that soothes you... hookers and cocaine arent necessary for this install tho...
DaBlackBox
134
04-10-2022 03:04 PM
TotalChaos
13
02-04-2015 11:24 PM
wiltonhall
01-28-2015 04:46 PM
carid
01-22-2015 01:49 PM
TheRedBox
31
12-02-2003 05:53 PM
Quick Reply: ES motor mounts/bushings install question? cost?
