Font sway bar?
Old 07-08-2006 | 12:20 AM
kyle1745's Avatar
Default Font sway bar?
Ok I have done the following to my car:
Front and reart Hotckiss sway bars
Front DC Sport Strut bar
H&R coilovers
rear camber adjustments
Alignment with 1.5 negative camber in the rear and the fronts are about .5 negative.
I just got back from a track day at Mid Ohio and seemed to be pushing a little bit. Now has anyone with a similar setup corrected this with reducing the front sway bar to the lower setting?
Thoughts?
Old 07-08-2006 | 12:35 AM
SquallLHeart's Avatar
i would have the front sway at the lower setting and the rear at the stiffest.. see how that works out for ya.
Old 07-08-2006 | 01:16 AM
1widetc's Avatar
Pushing as in the rear end wants to come around...
WHat are you lowered on?
kyle1745's Avatar
I was thinking about that. The rear is on the stiffest, but I may get new tires first. Trying to kill off these factory ones before getting new ones.
Old 07-08-2006 | 01:17 AM
kyle1745's Avatar
No pushing as in the front... rear is planted like crazy and does not move.
Old 07-08-2006 | 03:19 AM
engifineer's Avatar
Yep, push is understeer, which a fwd has too much of to start with. A stiffer rear sway will promote oversteer.. which is a little more controllable and useable in the correct amount. A stiffer front will add understeer. As mentioned above, I would keep the front on the softest setting and stiffen the rear if needed, this will help balance it out a little more
Old 07-08-2006 | 03:59 AM
hawgs74's Avatar
Anybody sell just the front yet?
yupinmytC
22
07-27-2024 07:08 PM
gedster314
Regional - Pacific South
02-19-2021 07:51 PM
SloTC1
08-16-2018 02:45 PM
babyfac3pn01
10-19-2015 07:24 AM
WarpedOne
09-15-2015 06:53 AM
Quick Reply: Font sway bar?
