Front brake caliber's rebuild?
Okay i have an insanely loud squeaking noise coming from my front brakes, so I took it into a shop and they said they have to rebuild the brake caliber's because the pistons are sticking. I had ceramic pads put on while they were trying to get a hardware kit because they don't have one for the Tc. They said the only place to get it from was the dealer and it was $95. bucks and that I'd have to buy it if I wanted them to rebuild it. My question is, how hard it is to rebuild them and should I just buy the kit myself and do the work?
Thanks!
Thanks!
That sounds... odd. I would maybe look to get a second opinion. Without seeing them, it sounds like you might just have really low pads and there is a piece scraping the rotor as you're driving. How are your pads? Is the rotor in decent shape?
My pads are only a few months old and still have a lot left on them. Rotors are dirty, but not warped. I thought maybe something with the heat shield but it's fine too.. It only makes the sounds when I'm braking around 40-50mph and from 70-80mph.. He said the rotors are getting way too much heat from the pads sticking. Said it was caused by pistons sticking.
I guess it's possible. I don't know much about having the calipers rebuilt though - never had to go through that. I'd also look into how much replacement calipers would be. If not from your local dealer, look up on TRDsparks.com (and click the OEM parts search on the right).
Check this:
http://www.trademotion.com/partlocat...layCatalogid=0
This is for an 09 tC (not sure what year you have) but they should all be the same anyway. You can get the caliper, the piston, or an "overhaul" kit... which I think is what you'd need for the rebuild.
Check this:
I'll definitely be hanging around this site for a long time.
have you thought of checking the sliding pins of the calipers? Those can lose their lube over time and cause the caliper to stick. If those are dry (no lube) then there's something to try first.
Ghost: That's a great deal compared to the $160 he quoted me to get both rebuilt.
update just found the toyota part
08887-01206 it's called rubber grease, it's actually a lithium soap glycol grease that the service manual says to use, works a lot better than the silicone the mechanic was trying to use.
yeah that lube is what happened with mine, the sliding pins needed to be lubed up and caused the one pad to wear slightly faster. Others have ignored lubing up the sliding pins, and the caliper actually seized that pin inside the housing. ouch. so hope that is what helps cure it, cheaper than a new caliper. i'd say it's like every 15k miles those pins need to be lubed. There is a special lubricant that toyota uses, one mechanic used silicone on mine and made it all "gummy". so try and find the right stuff
UPDATE: Just an FYI, I had them look at my brakes again and this is what was causing the squealing. When I had my ceramic pads put on, it wasn't properly on and was slightly touching the rotors incorrectly, causing a small rut in the rotor. So they sanded down my pads and rotors to a smooth surface and the squeal is gone!
evolving_machine
10-21-2023 01:16 PM
TheTripleC
01-04-2015 06:46 PM
