Front Sway Bars - are they any good?
Questions for folks with the front sway bar ( with the rear sway bar I guess).
Is the ride or handling really any better with a front sway bar and the rear sway bar vs. with just the rear sway bar? (not the strut tower bar)
Ed
Ed
They are supposedly very difficult to install so I would hope any benefits would make it worth the price and trouble to install. I would like to know what people think of their setups with an aftermarket front sway too.
Re: Front Sway Bars - are they any good?
Ed
Ed
i've heard good things about the "hotchicks" sway bars. you should look into these.
trust me, the front bar is a biatch. Anyways, if you use only the rear/front bar of a set and not the other in conjunction, your car will be not be well balanced, and you'll have massive oversteer/understeer problem. I'd just use both bars.
Ive installed the rear on my car - piece of cake! Now the front is another story Im told... I think you even have unbolt the rear engine mount. Read this thread:
https://www.scionlife.com/forums/viewtopic.php?t=61375
i just went outside to have a gander at the front. much much more work then i expected. the way the front is setup require much more work and equipment for a proper install
i stand corrected. the rear is doable for any DIYselfer, but the front will require much more attention.
I recently put in the hotchkis sway for the front and rear for my XA. Rear was done in ten minutes. THE FRONT SWAYBAR REQUIRED ME TO PUT IT UP ON A LIFT DROP THE SUBFRAME, THEN DROP MY CROSSMEMBER. There are MANY steps that I just blacked out from trauma. The ends justify the means, Your body roll will become non existant. Granted the sway bars were the last in a long line of suspenion work I did. You might still have the body twist without performance Shocks, Springs, Strut bars (front and rear) but keeping a 90 degree corner under control at 50 mph is priceless. I hear the front for your TC will get just as nasty as my XA so make sure you have a entire day to do it.
kleecker
01-09-2015 02:26 PM
TheTripleC
01-04-2015 06:46 PM
