GREDDY STRUT BARS
Old 06-14-2005 | 04:55 AM
daewonder's Avatar
all i know is that when i used the spacers the end mounts sat a lot better then they did w/o them. especially on the driver's side.
i'm still trying to think of a way to remedy this. if i can't, i'll probably just take it off.
Old 06-14-2005 | 03:33 PM
VoLktc's Avatar
did you jack up the car so both of the front struts were off the ground when you installed it>? that makes one hell of a diffrence in performance and install
Old 06-14-2005 | 04:38 PM
flintTC324's Avatar
yup I also jacked up the car, and had to stand on the wheel to keep it down, thereby pulling the bolts down to slide the bar into place. It didnt just make installing the bar easy, it made it possible. I cant see how else I could have done it.
Old 06-14-2005 | 04:49 PM
slammed's Avatar
Got it installed today. I used every spacer...dont see why you wouldnt use them. I had to do no dremeling of any of the body of my brand new car and it took 15 minutes. The hardest part was reinstalling the plastic windshield piece.
Old 06-14-2005 | 04:54 PM
VoLktc's Avatar
do your nuts fit better than his? yes i know it sounds bad
Old 06-14-2005 | 05:37 PM
flintTC324's Avatar
LMAO
I hope they do!
Old 06-14-2005 | 10:34 PM
Onikage's Avatar
So slammed and flintTC can we get pics of your install? It seems maybe he wasn't aware of jacking up the car so that's the reason he had to cut it. Too bad, but hopefully everything works out.
Old 06-14-2005 | 11:01 PM
flintTC324's Avatar
I dont have step by step pics during the install, but you can see a few pics of it after its in here:
http://www.wholesalehyperformance.co...duct-page.html
I have more, and can take new, closer ones if you need me too.
The whole install was quick and easy, I just went along with the instructions.
Old 06-15-2005 | 12:50 AM
slammed's Avatar
Jacking up car? I didnt have a need to do that. This mod is really to easy to provide pics but I will get a final pic tomorrow. All you do is pop out the plastic windshield piece unscrew the 6 strurt bolts then mount the two blue bases. The area that the other guy dremeled can be accessed with a crescent style wrench as opposed to a socket. Once the blue bases are in install the bar and put everything back together.
Old 06-15-2005 | 05:24 AM
VoLktc's Avatar
while jacking up the car is not needed it relieves stress from both struts during the install so that the bar can actually hold them both together better if you redid your install jackedvsnonjacked im sure you would see quite a diffrence
Old 06-15-2005 | 07:01 AM
slammed's Avatar
thanks, did not know.
Im installing my coilovers and injen intake later this week so car will be in air anyways
Old 06-15-2005 | 07:42 AM
daewonder's Avatar
ok i had the car up on jacks and i still couldn't get the nut between that metal lip and the top of the strut bolt once the spacers were on.
anyway, do you both have the same result with the nuts not going down very far? i'm anxious to see pics.
Old 06-15-2005 | 02:33 PM
Joe_Dezod's Avatar
That's weird. I have the Hotchkis bar and have taken it off numerous times to get to the back of the motor and the nut clears fine if you just bend that metal back about a 1/4 of an inch. It's such a slight bend it goes back to how it was when you leave it alone.
The Greddy bar is a lil awkward looking to me. So far I like the design of the Hotchkis and DC sports. But we will find in time how they all perform compared to eachother.
Old 06-15-2005 | 03:29 PM
slammed's Avatar
In the 2nd picture the top left nut is the one everyone is talking about. I just bent it slight ly out of the way and way able to fit riser and nut back on without much modification.
Old 06-15-2005 | 04:11 PM
VoLktc's Avatar
hmm i think ill just uses the nuts that came with my SS-P's on the install
Old 06-15-2005 | 04:30 PM
daewonder's Avatar
so the thread loss problem is just part of the install..
i've been thinking about trying to find shorter nuts. will that make any difference or will it be the same as using half of the stock nuts?
Old 06-15-2005 | 05:17 PM
flintTC324's Avatar
GReddy almost always produces top notch products. But if thats the way all of the bars go on, then DC beats em this time hands down. The DC bar is less expensive, utilizes a dual bar design, and in my opinion just looks better anyway. Plus from what we see in these pics, the DC bar leaves you with all the threading you need to feel safe and secure once the bar is on, not like the GReddy which looks like its barely secured.
slammed's Avatar
im pretty sure it wont matter as long as you have them torqued down enough
Old 06-29-2005 | 04:56 AM
JSG's Avatar
JSG
I build custom firetrucks for a living and will tell you this... Our standard is a minumum of 3 threads above the nut. This setup with the spacers looks completely unacceptable to me and very unsafe. Please think about it and take care.
Old 06-29-2005 | 03:04 PM
DTRUONG_112's Avatar
that does look unsafe.
Quick Reply: GREDDY STRUT BARS
