Gtspec front stru bar coming soon
gtspec Strut bar come with double internal hallow wall struture for stronger support. The actual bar is make of alumimum with high polish. Constructed by air craft 6061 grade aluminum for rigidity and strength. msrp price goine be around $161. we are also going make subframe reninforcemnet brace ,4 point ladder brace and maybe trunk cage..
Besides stuctureablity, what else does these braces do for the car. I think if you made a daily driver too stiff (especially the tC), i do believe it would creak alot more than it already does?? Please explain... I might be interested if the price is right and the explaination.. thanks.
Gtspec Strut Tower Braces improve chassis rigidity and reduce flex that strut towers experience during hard cornering. GTSPEC strut tower braces are made with 6061 aluminum, featuring a unique CNC cut connetor. By using the CNC cut connector to attach the center shaft to end plate, the result is more rigidity and able to absorb more force during turns. When taking a turn a car’s strut towers normally flex, resulting in body flex and some traction loss. GTSPEC strut tower bars are designed to keep your strut towers from flexing and distribute the pressure applied to one strut tower when taking a turn to both towers instead of just one. This keeps the wheels in position. By keeping the wheel in position, the car are more predictable and overall improve the responsiveness of the vehicle.
Available Version:
Type D - Wide Center Shaft
Type F - Flat Center shaft
Type R - Round center shaft
Type C - Dry carbon fiber center shaft
Type Ti -Titanium center shaft with steel side plate
Type FT -Full Titanium including side plate.
http://gtspec.com/index.php?nav=prod...ategory&cat=79
Available Version:
kleecker
01-09-2015 02:26 PM
TheTripleC
01-04-2015 06:46 PM
