H&R Rear Sway Bar review
Team ScionTific
It's time for another review of German-made suspension goodness from H&R, this time it's their rear sway bar. Here are the vitals: it's 24 mm thick (+5 mm OEM, +4 mm Suspension Techniques [Rear], +2 mm TRD/Progress, -3 mm Hotchkis [Rear]) and is nonadjustable. Purim/Teflon composite bushings are included, and "stoppers" are welded onto the bar to prevent lateral movement.
Installation
Installing the H&R rear sway bar is fairly straight forward and can be done on a level driveway with jack stands and hand tools, however, removing the previous rear sway bar can be a difficult, especially if it is an aftermarket bar with longer bar ends.
I'll spare you the details and refer you to this HOW TO thread --> https://www.scionlife.com/forums/viewtopic.php?t=30052
After removing my TRD sway bar, the H&R bar is installed using the previous end links, bushing brackets, and H&R-supplied composite bushings that eliminate the need for lubrication. The bar can be put in place (H&R logo facing down) without removing the axle-back exhaust, and thanks to it's shorter bar ends, installation is easier than other aftermarket sways; as with the H&R coilovers, build quality is excellent, and the end links slide easily into the mounting holes.
Handling
Going from the TRD sway bar to H&R provides a subtile, yet noticeable improvement in handling without negatively affecting comfort over uneven pavement and matches well with H&R coilovers (of course), but the sway bar will work well with any suspension combination. Understeer was slightly reduced over the TRD sway, however the bar is not so thick as to create snap oversteer issues. Thanks to a further reduction in body roll, my slightly larger-than-stock Falken Azenis 615 tires don't rub during aggressive cornering as they did with the previous sway bar.
As always, different damper, springs, and sway bar combinations will yield different results, but the H&R rear sway bar is another welcome option for tuning the tC suspension. If you're interested in the thickest rear sway bar without suffering from snap oversteer or having to buy a front sway bar, H&R may be what you're looking for.
Installation
Handling
H&R definitely makes nice stuff. Did you find a good deal on it? I know that it's MSRP is kinda high for a rear sway... even though H&R is worth the bit of extra $ you might pay.
The non adjustable part kinda worried me... but it looks like the one hole in the H&R lines up pretty close to the race setting of the TRD... so that wouldn't be so bad.
Team ScionTific
Originally Posted by eliXion
i didnt even know H&R had a rear sway. where did u get it from?
Team ScionTific
is really worth the extra $75 compared to the TRD?
definately a nice product, and another great review as usual.
i am most likely getting this sway bar due to the fact that it is the thickest, yet is made solely for a rear sway bar without conjuction with a front sway bar, the front is just to hard to swap and i dont believe that its worth it.
airmankevin1
02-14-2018 01:23 PM
Squishface
09-15-2015 06:51 AM
TheTripleC
01-04-2015 06:46 PM
