HALP! Bent my rear "axle" crossmember / subframe!!
Scion Dynasty
Alright guys, tapping the collective knowledge of the group.
I am in the process of installing Energy Suspension's rear subframe bushing to fix the slop that is in the stock rubber ones. Got out my three-jaw puller and popped out the first stock bushing without incident. I start torquing down on the second to pop it out and... BANG!
My puller, pusher plate, wrench, and subframe all go flying in different directions... no bushing, though... I meander over to the subframe and...
OH *@#&, I bent my subframe! Not only did the puller collapse the rectangular tube of the subframe, but the seam weld holding the bushing cup to the tube started to fail as well. So I figure my options are thus:
1. Take the whole assembly to a blacksmith / metalworker / welding shop to have the tube reformed, the cup welded back on, and some type of fabricated brace welded around the whole connection, or...
2. Search around for a salvaged crossmember and start from step 0,
Thoughts???
Thoughts???
I vote for solution #1. Why? If you get a used one, who's to say it won't break too? Really makes me wonder if this is a weak area on all tCs...since you already have it off it shouldn't cost much or take long for a machine shop to make it stronger than stock, so just do it.
kleecker
9
08-02-2022 05:00 AM
carid
02-12-2015 11:54 AM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
