Help! Broken wheel bearing
Lately I've noticed that my front passenger side squeals a lot when I'm coming to a stop so I checked it out today... I found out that one of my wheel bearings are cracked and broke off when I took off the lug nuts.
So I'm changing the wheel bearing right now and I'm stuck cause it won't come out. (pics below) I tried hammering it out, but it won't budge anymore. Any suggestions?
I'm actually tempted to remove the whole hub. Does anyone know what size the bolt is the holds the hub?
Thanks
Thanks
HaYu Racing
i had to do this also when someone tried to steal my rims. i guess maybe they turned it the wrong way. but trying to get the stud off is PITA. just keep hammering the crap out of it though until it pops out. cant really give you any other instructions besides that, because that is what i did.
this is an easy fix. Open your hood and I beleive the screw you need to use is one that attaches your radiator to the front. Unscrew it and use that to screw into the open hole on your hub at some point as you screw it in you will hear a "pop" and your hub will pop off. Then unscrew the bolt and replace it back in the place you took it from. Easy as pie.
good luck.
By the way.....you can hammer all you want if you re feeling like you need to take out aggression but you will save blisters, banged up hands and about 2 hours of your time doing how I said above!
good luck.
good luck.
good luck.
CombatmedicR56
11-12-2020 01:53 AM
fur_pig
03-20-2020 04:28 PM
xdejablu3x
04-19-2017 03:44 PM
