hotchkis bump stops on H&R sport springs? yes or no?
Old 05-08-2009 | 03:53 PM
huslindan's Avatar
Default hotchkis bump stops on H&R sport springs? yes or no?
so i am installing my H&R lowering springs on the 14th ( got time to do it now since school will be over) and i was wondering should i use the hotchkis bump stops or the oem ones?
Do i even need to cut the oem ones on that mild of a drop? (1.4 in the back and 1.3 in the front)
or should i order the hotchkis ones iv emailed them and they said they would sell me a pair?
this is my first time installing springs with oem struts. so i need help on this
THANKS
_Dan
Old 05-08-2009 | 05:12 PM
hawaiiguy's Avatar
though i have a xb, the sheet that came with the H&R springs indicated that you would have to cut the oem bump stops for the TC
Old 05-08-2009 | 05:18 PM
mason098's Avatar
i just recently put the trd springs on my stock struts and i cut the bump stop a little bit but not much i dont think you will need to get them because i think the trd ones are lower so i think your fine if you just cut them
Old 05-08-2009 | 06:02 PM
huslindan's Avatar
yes it does indicate that you should cut the oem ones but ppl that put the trd springs on say you dont really need to. so if you dont really need to cut them i wouldnt want to. but if you have to cut them id rather just use the hotckis ones unless those are to short.
Old 05-09-2009 | 01:19 AM
Mos_Def's Avatar
huslindan, i have the H&R sport springs installed. the chart says you dont have to cut the bumpstops, only for the H&R race springs. it specifies for the tc to only cut for the race springs part number.
Old 05-09-2009 | 01:32 AM
huslindan's Avatar
can you post pics ?
Old 05-09-2009 | 02:26 AM
Mos_Def's Avatar
REAR
FRONT
this was the side view with the TRD's
much more even now with H&R sport springs. i will post in the lowered TC thread a side by side comparison of both when i take a pic of the side.
Old 05-09-2009 | 02:31 AM
huslindan's Avatar
are you on 18's cuz im on 18's would using the hotchkis bump stops be bad ? you think?
Old 05-09-2009 | 02:37 AM
Mos_Def's Avatar
im on 18's. im not too sure about the hotchkis bumpstops. i didnt cut or replace mine and i like how the car sits. i have stock struts also.
Old 05-09-2009 | 02:41 AM
huslindan's Avatar
oh and whats your off set? on those rims
Old 05-09-2009 | 02:42 AM
huslindan's Avatar
yeah ill be using stock struts also i like the drop also handling was inproved right?
Old 05-09-2009 | 05:57 AM
Mos_Def's Avatar
the offset is 42. handling is about the same, if not a bit better than TRD springs. i also installed TRD swaybar so handling has improved greatly.
Old 05-09-2009 | 03:43 PM
huslindan's Avatar
yeah i have the progess sway you dont rub at all do you man ?
like when you hit a bump or anything?
Old 05-10-2009 | 04:19 AM
Mos_Def's Avatar
nope not at all. you should be fine and content with drop.
XirtaXa
23
07-14-2021 05:33 PM
carid
02-12-2015 11:54 AM
TOY_bB
9
12-06-2003 05:15 AM
TOY_bB
11-29-2003 03:50 PM
Besk_one
10-27-2003 04:13 AM
Quick Reply: hotchkis bump stops on H&R sport springs? yes or no?
