How to Fix a Sqeaky Spring??
So my Right Rear Spring is Sqeaking in a High Pitch Tone to where its Annoying to listen to....If you push down and let go there's a High Pitch sqeak coming out...
Anyway to fix this?....Then again I dont even know if its the Spring either!
Aight Thanks in advance.
Alright....I think I fixed this problem!!
**crosses fingers...
Took off the wheel...Got some WD-40 Sprayed every bushing & contact points like the endlinks to the Rear Sway Bar etc...
Put the wheel back on...Wa-Laa...I was bouncing the crap outta the car...NO Sqeaky sound!!!
Originally Posted by Clean_XB
try wrapping the the lower half of coils that come into contact with eachother with vinyl.
it might be a pain in the butt because you might need to remove the spring off the strut.
I wouldn't recommend just taking WD-40 and spraying random parts
So do you think it is the springs after doing the (always temporary) wd40 fix? How about slapping some heavy duty grease on the contact points?
If it is the springs (what springs are they anyways?), you could try these Tein silencer rubbers link . I think you can use them on any springs, but verify with them first.
this is an old thread i know but i dont want to be harrassed by people saying i didnt search. so ive been noticing a creaking noise with my springs (s.techs) while going over bumps slowly. so today i jacked up the car and saw alot of green on the silencers. well i decided to grease up this contact point and the sound went away. so my question is has anybody taken the silencers off so see if its actually the silencers that are making more noise than reducing it? otherwise im just gunna get a tub of heavy duty grease and hit it up once a month or whenever the sound returns. i can live with it, its just annoying at times.
the strut isnt blown. It hasn't been lubed or anything, I will try that.
It makes a squeak as going up my drive way or such and my tire has a bit of rub from my fenders. The struts top part (under the hood) isnt pushed up. It never makes a knocking/rattling sound. And I have a buddy with a rear blown strut so I know what the symptoms are
mischadoll
03-09-2015 06:48 AM
fluxingnation
12-26-2014 05:28 PM
