How much gas in tank when corner balancing?
when one does corner balancing on the car, how much gas should be in the tank?
i tried searching, but did not find an answer. i was assuming maybe around half a tank...?
i say do it with a full tank of gas, under hard cornering, the gas can slosh around and you can experience fuel starvation. if your racing, it should always be on a full tank of gas.
the extra weight of the fuel would be less detrimental to your performance and handling than coming out of a corner, hitting the gas, and feeling the engine stall until the gas in the tank settles and fuel pump finially finds some gas.
yeah, Tc's have a horrible issue with fuel starving. Wasn't there a thread around here or from another forum that had a member show what he did to fix the problem?
Anyways, back to the OP's question I personally would do it with 5gallons. Thats how much I usually run in the car anyways.
BlingSlade
10-19-2016 12:39 AM
BlingSlade
11-20-2015 06:56 PM
