i need some opinions
Old 04-29-2009 | 06:35 PM
scion_327's Avatar
Default i need some opinions
hey guys, i'm new to SL and i just got a tc. i plan on workin on the suspension first. i'm avoiding the big drops bc mine has the kit and plus its my DD. i'm debating between TRDs and H&R.
please let me know which one has better ride quality or if i should avoid either of them. thanks in advance
Old 04-29-2009 | 06:39 PM
203superwhitetC's Avatar
i have h&r coilovers in my room waiting to be installed. i got them so i can adjust the height. ive heard excellent things about the springs. TRD is just too high. very close to stock height.
Old 04-29-2009 | 06:57 PM
RichTc's Avatar
I disagree that the TRD are too high. They will provide you with enough drop
(approximately 1.25') to give your car a more aggressive look and provide some handling benefits. Also, if you have 18s on it, there is minimal wheel gap (2 fingers in the front).
Also, from what I understand, if you lower your car more than 1.4' inch, it will result in a negative effect on the handling of your car.
Alot of is preference.
Old 04-29-2009 | 07:09 PM
Mrsanchez925's Avatar
TRD = MONSTER TRUCKING. IMO.
get some Tein springs or H&R springs..
if you have the money id say get coil overs...since most ppl eventually want to go lower...
Old 04-29-2009 | 07:11 PM
WhiteOut's Avatar
I had Ebicah then i made the move to the TRD's and never happier.
Old 04-29-2009 | 10:37 PM
nodsetse's Avatar
Eibach makes two types for the tC, "Sportline" and "Prokit", iirc.
You must've had the Sportlines, which have a stock spring rate but a very low drop.
The Prokit springs are essentially the same as the TRDs.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
CrowJenkins
10-09-2015 10:47 PM
spawnpigcharlie
09-29-2015 07:31 AM
crimson_sinn
09-25-2015 09:41 PM
ScionDP
09-08-2015 02:17 AM
Quick Reply: i need some opinions
