Install Ingalls Damper
#202
if your viewing damper from in front of the car so its on your left side. which way do you turn it to make it stiffer? to the right (tighty) or left (loosey) ? i got a hand me down with no intrsuctions thats why im asking?
or what would be the correct way to tighten it? to make it stiffer?
#203
#204
Originally Posted by BOXMAN
What does this have to do with the Ingalls piece? ^^^^^
#205
#206
All you are showing is you used a R&D design and adapted it to use a mountain bike shock? How is that a better design?
#207
R&D? No. I Just like how much more adjustable it is. Have you tested yours at the track yet? I've just seen people wiht Weapon R, Ingalls spending twice as much as I did and not be happy with it at all. I've felt them both, I like mine better. Thats just me, come to cali if you want to experience it.
#213
after running the stiffy for 2k miles, the vibrations at idle and when the a/c on is starting to annoy me. what was the best method in stopping such an issue? i already used 2 layers of raamat on the initial install of the product.
#215
How do I tighten my ETD once it is installed? For example I'm standing on the closest side of the Damper which is the passenger side. What do I turn to tighten it, and what direction. (righty tighty) right? I just want some help on it so that I know that i am doing it correctly.
Thank you
Thank you
#216
Thank you
Thank you
STOP you should never adjust the ETD on the car!!! go to www.ingallseng.com click on Stiffy applications then download the how to adjust the ETD instructions. Avoid breaking the stiffy and being out of that hard earned money. Ingalls wont cover damage from adjusting on the car.
