Install Ingalls Damper
#363
Originally Posted by Spect2K3
Yep, just make sure not to lay down too much dynamat (your layer is fairly thin). Some people overdo the dynamat and THAT is when its not doable.
#368
Originally Posted by nautyblu06
Tcguy85, did you have to completely remove the windshield wiper and guard?
#369
#370
Why not remove the wiper cowl/wipers? It takes 2 seconds, is easy as can be, and make life soooo much easier for installing the bracket. There is no reason to leave it on, it just makes life difficult. Its like trying to put on shifter cable bushings w/o removing the stock air box. Its 3 bolts for goodness sake and takes all of 25 seconds!
#371
I didn't remove it cause it didn't cause a problem for me. I just lifted the guard unbolted and slid the bracket on and bolt back. It didn't make anything harder to do.
#372
it didn't make it harder to do at all, and i also didn't remove my airbox when i did my shifter cable bushings either. there was no reason to remove anything on either job. why make more work for ourselves.
#375
hey i was just reading up on the because i might buy one and my friend that it would be a better idea to just go with motor mounts...b/c he had it and he said the mounts are a lot better and i don't have to deal w/ the rattles and poop b/c my car rattles a lot already b/c my idle is off i think and when i put my rear defrost on...i don't want this rattle to get worse...
#376
Its not going to make the car rattle if you use dynamat. That eliminates almost all of the vibration. I've never put it on 10mm, but i've tried everything from 12.5mm-15mm and no vibration thats worth speaking of.
#377
#378
#379
its not so much vibration, i dont have any at all, and no rattle in 20 degrees...i think the issue is just increased engine noise transferred to the passenger cabin. the rod acts like an amplifier. its a 'hollow' sound if you know what i mean. i am going to play with it a bit.
please don't tell me your cabin sounds exactly the same on acceleration..i will cry. its not god awful.about 30% volume on the radio drowns it out.
do you guys experience that?
