Install Ingalls Damper
#81
Originally Posted by Bluechualappa
Can someone post a picture of the part your suppose to tighten to make it stiffer? Circle it please... I tried last night but I'm not sure it was the right one. I tightened the small nut thingy before the chrome chamber( on the strut side of the damper)
DEFINATELY do not do any adjustments with it installed on the car.. here's a link for adjustment instructions....
http://www.ingallseng.com/parts/stiffy.htm
it's half way down the page in red text that says "click me"
#85
Re: 1st and 2nd gear??
Originally Posted by FLINT
Originally Posted by wtc_81
So is it a poblem that the car sounds like its gonna stall in first and second gear?? is there away to fix that?
#86
yea it viberates but its not bad, my top bolt by the strut tower came loose and i just tightened it back down...i rushed to put the thing on since i had work and other things to do the day i installed it ....but other than that its good
oh and if the bolts arent tight enough it will attempt to stall or run a super duper rough idle...which doesnt pose good for the motor since the car is like a bouncing bouncy ball when its like that
#87
#89
Some pictures of it with powdercoated brackets:
https://www.scionlife.com/forums/viewtopic.php?t=105447
#91
looks great!!! How much did you spend getting these powder coated? bump
#93
Originally Posted by schwettynuts
Yes, you can still use strut bar. click my profile and youll see the picture.
did you put the braket for the dampner under the strut braket? , if you did that wouldn't you have to raise the other side so its even?
#96
https://www.scionlife.com/forums/vie...hlight=ingalls
in the first pic it went ... car>damper bracket>sway bracket...dc wont fit with o.e. suspension and damper bracket...However...
IT will fit a dc with after market suspension that has the longer hardware that is usually 10mm+ just to anticipate a sway bar bracket...
The thread above is fittment on a hotchkis bar...
he uses dynamat on the other side to fill the gap which I would recommend doing under the Ingalls bracket to minimize resonation..
#98
Anybody have the Ingalls damper with a Tanabe Sustec Strut Bar? Im also running TRD struts in case that matters in bolt size, just curious if I can fit this mod without issues on my setup. Hows the reviews for Auto TC's ?
#99
Well, still no real answers about my setup from Ingalls or CorsportUSA. Ingalls said: "I think it will fit but I want to make sure" but later in the day I got: "the engineer said that there might be a clearance issue with the bar itself". I sent some pictures of my setup to Tai @ CorsportUSA but no response yet. If nobody seems to know I might have to just take a chance, pick one up and inform the community. If it doesn’t in fact fit I may just sell the strut bar if the damper in fact seems to be the better of the two performance improvements.
