knocking when i hit bumps
so i took my car into firestone to have them check on a knocking noise when i hit bumps.
just as i thought i needed struts...all FOUR of them are bad...i have s-tech springs btw, 63000 miles
should i get OEM struts or go aftermarket?? and from where should i purchse for the cheapest price??
It may be coming from the strut caps or the nuts may be loose, I'm running s-techs with stock struts and been running them for quite some time and no issues plus on top of that it takes a long time for struts to wear out for Toyotas/Scions. Strut caps are around 60 a piece from the dealer and it would be no need to replace the strut itself if that's the issue first thing I would do is to check the top nut and make sure it is tight, Firestone doesn't know jack _ _it in my opinion.
I just installed Eibach Pro-Kit springs with KYB G2R Struts, i started hearing a noise on the front driver side as well, i only hear it when im going slow over bumps. Im letting the springs settle a bit before i get it aligned. I have frequently read that it could be because of the ball joints, But im not sure. I'll recheck all the nuts this week, i wanted to do it today but my car is to low to get the jack under the front bumper...LOL
just touch your strut. if ur strut is oily, it's blown. if it's more of a creaking noise it could be one of 3 things, I've had all 3 happen to me. 1) Blown strut 2) Fender lining is bent and now rubs the tire(mine has a hole rubbed through it) or 3) You smashed your bump stops and they're no longer there. Check all 3. Unless u got oil on ur strut, if u do, it's a blown strut.
yeah do it. I've had to pull my suspension more times then I can count since I got this car. I've blown up 3 sets of bump stops, one set of struts, blew up my front passenger strut and my fender lining might aswell not exist. And i've only been dropped for 2 years <3 new york roads.
[QUOTE=a_german_named_hans;3699584]yeah do it. I've had to pull my suspension more times then I can count since I got this car. I've blown up 3 sets of bump stops, one set of struts, blew up my front passenger strut and my fender lining might aswell not exist. And i've only been dropped for 2 years
