Monster Motorworks TC Rear Strutbar ! More Pics...
Old 07-27-2005 | 06:08 AM
  #41
Weapon-R's Avatar
its about 1" x 1" cut out of the foam inserts.
Old 07-27-2005 | 02:23 PM
  #42
Schuller's Avatar
I'm pretty sure the only thing that bar will do for a TC is please your eyes. Kinda like my umnitza intake but at least the intake will talk back back to you "wroooom".
Old 07-27-2005 | 03:39 PM
  #43
squirrel's Avatar
Rick (raamaudio), this is squirrel from MO. Monstermotorworks is very much interested in getting the best performance out of all Scions. I have had numerous conversations and discussions w/ them about what may work, and what may not.
Monstermotorworks is not in the business to sell products that will not benefit the car and the owner. They want a product that will benefit everyone.
They do ALOT of R&D before even releasing any info on a product.
If enuff peeps are interested in making a GB on a particular product from Monstermotorworks, let me know. I can call them and try and set something up w/ them.
I don't own a tC, but I know what will be instore ofr xB owners in the future.
Old 07-29-2005 | 02:21 AM
  #44
tckurt's Avatar
N.G.S.O.
what would the retail be on the intake manifold?
Old 07-29-2005 | 11:14 AM
  #45
BrEaK_AwaY's Avatar
such as thair battery cover that can hold in moisture to help corrode the battery terminals
Old 07-29-2005 | 01:11 PM
  #46
matty-tC's Avatar
pwned!
Old 07-29-2005 | 03:47 PM
  #47
squirrel's Avatar
I was refering to their suspension and intakes, as I have had much discussion w/ them about those particualr items. I didn't have any discussions about the battery cover. I thought the positive and negative battery terminals were exposed and not sealed.
Owned!?! I don't think so. Matty, I don't see you coming out and using your money to make products for the tC. Maybe you should sell your tC and get a Civic instead w/ an attitude like that.
Old 07-29-2005 | 05:53 PM
  #48
BrEaK_AwaY's Avatar
you said they put alot of r&d into their products. this is one of their products, and it is horrible imo. as well as their radiator cover.
Old 08-01-2005 | 01:20 AM
  #49
mahalzkita28's Avatar
hey breakaway, why are you talkin shiz? you havent even seen these products in person? my friend has the battery box and the terminals are outside of the box so i dont know where you go that it holds in moisture and it will make the terminals rust.
i also have the rear sway bar and it DOES make the rear alittle stiffer. its just like a front strut bar, it wont do much of anything by itself but when you have a fully built suspension and you push your car to the limit it will make a difference.
Old 08-01-2005 | 02:19 AM
  #50
BrEaK_AwaY's Avatar
lol... wow.. ok lets see
1. well no crap that terminals are outside the box... if it wasnt, no connections could be made to the battery. but the space under the battery cover can hold in moisture, which is VERY close to the battery terminals, which can help them corrode, not RUST as you said.
2. and yes, the rear SWAY bar does make a differance as you said. the rear STRUT bar does not. but in no way is a rear SWAY bar like the FRONT STRUT BAR as you said.
all in all. read what you are posting before you post.
here's when matty replies again and says "pwned"
Old 08-01-2005 | 03:51 AM
  #51
Motorsport_TC's Avatar
I think he meant rear strut bar and accidentally typed swaybar. Also usually you run those felt terminal protectors which Monster Motorworks did reccommend to run which would block off the moisture from the battery box
Old 08-01-2005 | 11:51 AM
  #52
BrEaK_AwaY's Avatar
the felt protectors would help. but are not needed at all if you dont have that bettery cover. reguardless if you have the felt or not, it will still damange your terminals MUCH faster than a betteries terminals without the cover.
JonathonK
02-16-2016 11:21 PM
carid
04-07-2015 02:21 PM
xa007xa
03-29-2015 10:28 PM
stenger
Regional - Mid South
02-12-2015 07:13 PM
TheTripleC
01-04-2015 06:46 PM
Quick Reply: Monster Motorworks TC Rear Strutbar ! More Pics...
