Are my Calipers Frozen??
Old 09-05-2007 | 12:07 AM
clayisland485's Avatar
Default Are my Calipers Frozen??
I need some help, my brakes seem like they are "stuck" on, not all the way though, just enough to hear an annoying hissing as the pads are continously against the rotors. When I take the caliper off, the piston is in the extended? position. I've tried bleeding the system(which I only THINK I did right...rear left, rear right, front right front left?) Any ideas are appreciated
Old 09-05-2007 | 01:19 AM
Anyone?
Old 09-05-2007 | 01:28 AM
draxcaliber's Avatar
i don't know if your calipers freeze, but could the cylinder go bad?
Old 09-05-2007 | 06:28 AM
REVOSOLDIER's Avatar
is the dust blocker or w/e bent possibly rubbing the rotor? were all the calipers extended the same distance? if so i dont think thats the problem...
Old 09-05-2007 | 06:39 AM
kileil's Avatar
There usually is a tiny bit of contact between the pad and the rotor. If you just swapped rotors, its also common for the pistons to extend a bit as the caliper is hanging free while you're doing the swap. Again, no big deal.
If you can turn the wheels relatively easy by hand with the car in the air its probably not a problem.
You could also take it for a drive in a quiet neighborhood and try not to use the brakes. Use the clutch and let it roll to a stop. If your wheels still feel cool (dont touch rotor) after youve let it roll to a stop youre probably fine.
When bleeding brakes, stick some surgical tubing over the zerk fitting on one end and stick the other end in a container of brake fluid to prevent air from getting in while you pump. Easier if you have a friend to work the pedal.
Old 09-05-2007 | 01:47 PM
its not the dust blocker, if I remove the pads, the rotors spin free, but as soon as i put the pads on and bolt back on the caliper, and try to spin the rotor, it makes a scraping noise. Its worst on the Rear Driver's side, but also noticable on the rear Passenger's side.
Old 09-05-2007 | 04:57 PM
did you swap out for a big brake kit or slotted rotors? im not sure you said if they were stock or not.
Old 09-05-2007 | 05:08 PM
they are just OEM replacemet rotors from brembo, cross drilled
Old 09-05-2007 | 05:46 PM
hmm....well i guess maybe they are just a millimeter bigger or a very small bit. have u taken it to a shop?
Old 09-05-2007 | 05:50 PM
Well its been to the dealer twice already, and its still doing it, so im hoping someone that actually knows something about these cars will help me out lol
Old 09-05-2007 | 05:56 PM
also, I might try and put the OEM rotors back on, and then see if it still does it...it could be the brembo rotors are too big like you said soldier
Old 09-06-2007 | 03:04 AM
ya i mean u know prolly more than i do...just tryin to help thats all...lol good luck bro..
Old 09-06-2007 | 03:22 AM
Oh no bro I didn't mean that towards you, I meant, I took my car to the dealer, didnt get it fixed so i thought I'd come on here(where people actually know stuff about our cars) and ask lol
Old 09-11-2007 | 10:30 AM
JOEinSD's Avatar
i have this same noise coming from the driver's front. it's so annoying, espcially when it's quiet. that's all you hear- a scraping noise from the wheel. i looked around the wheel and nothing looks out of place...
Old 09-11-2007 | 04:58 PM
ya ik clay i was just sayin but ne luck yet? joe take off your wheel and look behind the rotor maybe ur brake dust cover is bent a little? have you done brake mods?
Old 09-11-2007 | 06:57 PM
I got a power Bleeder from killertc.com, and completely flushed the system...The bad news is, I also layed down a few layers of dynamat in the car, so i can't hear it driving lol, I'm going to have to let my girlfriend drive by me on the street and see
Old 09-11-2007 | 07:34 PM
JOEinSD's Avatar
no brake mods. it's all stock down there. but i'll take the wheel off and check it.
if you really want to hear it, drive through an alley next to a wall/building.
rvascion
11-12-2020 03:23 AM
gqdabien
07-22-2015 10:30 PM
nightwitch
07-14-2015 01:58 AM
Tak16
07-07-2015 05:45 PM
Jmarks1998
20
01-08-2005 02:56 AM
Quick Reply: Are my Calipers Frozen??
