New brakes and caliper hits rim
I got the Axis Ultimates and when I tried to install them the inside of the rim hits the brake caliper. Im just going to grind the caliper down enough for clearance, sound ok?
Re: New brakes and caliper hits rim
it does because of the thickness of the pads. i never would have thought to check before i tested them. first time they messed up my rims a bit but not a big problem. just tested them and its all good now.
calipers are a fixed size, and it's the piston within the caliper that push the pads against the rotors to make your car stop. if you only changed the pads, then you would have a harder time getting the caliper to fit over the rotor, than having issues with the rim rubbing. meaning....that something is not re-installed correctly. it's not the pads.
evolving_machine
10-21-2023 01:16 PM
Squishface
09-15-2015 06:51 AM
TheTripleC
01-04-2015 06:46 PM
Slopoke21m
54
04-23-2007 12:25 AM
