NEW! Dezod V2 Rear End links for the tC
#45
Originally Posted by cabrera1985
How much for the front endlink shipped to 92703? Do u have in stock?
#46
Hey Paul...just got my endlinks in today...installed...sort of...
The endlinks are supposed to be completely vertical...does that mean if they are at an angle right now I adjust the height up or down?
Someone mentioned that the sway bar should be parallel to the ground but which part (the angled part after the part where the endlinks connect to)?
Thanks in advance!
Thanks in advance!
#47
Thanks in advance!
Thanks in advance!
#48
you won't be able to get the endlinks perfectly vertical nor will you be able to get the bar perfectly parallel to the ground, but you can adjust them to be pretty close.
as for what part of the bar you want to be parallel:
maybe its just me but putting it so close to this spec seems to apply more pressure on the bushings thus making them squeak like a ****, even after taking it apart and using lithium grease. however i am still troubleshooting if its the tightness of the sway bar or something else, going to take it apart again this weekend and try to pinpoint the noise, maybe loosening it up a little to give it more play will help. then again it may not even be the bar.
#50
Correct. These endlinks have a decent adjustment span to accomodate for a few different adjustment spans.
#52
well i did a little adjusting today..
jacked up the car and took both rear wheels off, took both endlinks out and the entire sway bar with the bushings. cleaned up everything with engine degreaser and wiped it down good.
i compared the oem endlinks with the dezod's. since i'm lowered i went ahead and adjusted them to be even shorter than the oem endlinks. i lubed up the inside of the bushings with the lithium white grease, as well as the outside curved part that goes into the metal bracket, and on the frame of the car itself, the big flat spot that the bushing bolts to. i bolted everything up tightening it evenly as i went. when i was all done i took it for a spin and sure enough, no sqeaks and the endlinks are adjusted ever better than before, so now i have basically no play at all.
#53
#54
you should have gotten 8 of those thick black washers in your kit. here is how mine looks after yesterday:
note, the silver washer is something i added. if you go on the dezod site they have theirs with a lot of washers, which helps illiminate the endlink rubbing on the swaybar (which mine was doing before i redid it all).
so mine is like so:
Bolt -> black washer -> endlink -> black washer -> (my) silver washer -> car frame -> nut
for the top its the same just replace car frame with sway bar.
so mine is like so:
#57
I guess I gotta go buy more washers then... My kit only came with some thin washers
#58
#59
#60
