new spring noises?
new spring noises?
Ok, I just got my trd lowering springs and hotchkis front/rear sway bars installed yesterday. I had it done at a local shop for a nice price that I couldnt pass up. Anyway, after I got everything installed, I started hearing this odd noise in my car that I never had before. It isnt a metal against metal clanking sound, I cant really explain it. The sound is more constant when in a parking lot. You know that large parking lots have a constant up/down surface so to prevent speeding (i would think) so that it feels like your riding a wave or something? Well thats where I can hear the noise. That and also sometimes on the streets. So the noise isnt from any turning, which I think eliminates the swaybars as the cause. Well, is this noise normal for new springs? Should I wait another 2 weeks to see if it goes away? Sorry for the noobish question.
if it is kinda like a clunk when hitting bumps then i may be able to help. After my spring install i had the same noise, the person that did my install fixed it. I inquired but was never given an indepth answer. More or less he did not fully reinstall something, I think a panel or clip. I would bring it back to the ppl that did the install and have them ck there work.
well not sure of this is a solution but I had a clunk noise and it was cuz the bolt on top of the struct tower was loose....not the 3 bolts but the one in the middle under the rubber cover..
hope that makes sence
i had the same problem for the past several weeks with my trd spring...i don't know what kind of noise you have but i have a clunkin sound fromthe rear in speed bumps, and sometime when i accelerate from stop or rough raod...noise came after 1 month after instal. i just found whats causing mine last thursday.. a loose bottom blot of the rear strut.. check all the bolt and torque it...
Is it more of a creaking sound?
I didn't have any strange noises after I got my TRD springs put in (i've since switched to Hotchkis, which creaked for the first couple days) but after I put my Hotchkis sways in, I got some creaking up front when going over uneven surfaces, like pulling out of my inclined driveway at an angle.
If that's the sounds your hearing, it's from stiffening up the chassis so much at once. It should go away in a few weeks. But I still get it every now and then on uneven surfaces at very low speeds.
No problem.
Your gonna love the setup. I had it for about 10,000 miles before I switched to the Hotchkis springs. A little stiffer, a little flatter, a little more even drop. Both are great.
I just want to be able to say that I got nothing but "Hotchiks" under me all day long!
theblue,
My bad. I didn't see your reply to this post.
I LOVE the sound of my Injen. It's great, deep, but not to loud. The only other exhaust I've heard that I like as much as it is the HKS Hi-Power.
RY_TC07
07-18-2017 05:18 PM
autobotxxtonyxx
12-23-2003 06:03 PM
