Newbie
Old 12-29-2005 | 11:59 PM
RanmaP's Avatar
Default Newbie
When installing coilovers
Does upgrading sway bars still needed?
What about camber kits? Do I need those due to lowering the car?
Is important enough to get so that tires will wear out evenly?
After the install of coilovers do I need to take it to a shop for re-alignment?
Thanks
Old 12-30-2005 | 03:14 PM
marinoTC's Avatar
sway bars would still help out a lot if you plan on doing autox or something.
if anything a camber kit will only be needed for the rear. but even so it isnt too bad without it.
and for the alignment. wait a couple weeks to let everything settle.
Old 12-30-2005 | 05:17 PM
WeDriveScions's Avatar
If your going to go auto-x, you'll need to upgrade your sways.... some run TRD, some run Hotchkis, the trd are definately much tamer, but do the job decently well...
It all depend on how low you go, if you need a camber kit... if you drop it REALLY low, it's probably a good idea, but if you go conservative, which is better for the suspension geometry anyways, it should be fine...
Coilovers should settle pretty quick, but get an alignment within a couple weeks for sure...
Old 12-31-2005 | 03:27 AM
RanmaP's Avatar
Default Thanks
No I am not going to auto cross... sometimes I just take those circular on ramp/off ramp on the freeway a little too speedy thats all.
Got it! Thanks a bunch.
Davyo
Scion xB 2nd-Gen Wheel & Tire
07-29-2015 05:53 AM
Ianno
07-07-2015 04:35 PM
scotttie17522
Regional - Northeast
12-12-2014 12:33 AM
tC6M
11-26-2014 06:44 PM
defytrends
04-12-2005 09:36 AM
Quick Reply: Newbie
