OEM rear sway bar squeaking? HELP!!
Old 09-02-2007 | 08:09 AM
sp0t's Avatar
Default OEM rear sway bar squeaking? HELP!!
Well, after re-installing my tein s-techs after having tein basics.. my rear sway bar has been squeaking like crazy. If I sit on the trunk and get off of it, it squeaks so bad.. at first i thought it was the springs against the perch but it wasn't. I sprayed the endlinks of the OEM rear sway bar with white lithium grease and it was gone.. temporarily. I basically have to spray the endlinks once a day.
Should I unbolt the rear sway bar and spray the insides (since im only spraying from the outside)... and if i do, do i have to jack up the car on both sides or i can jack it up one side at a time?
i'd appreciate your inputs. thanks
Old 09-02-2007 | 05:29 PM
ack154's Avatar
I'd probably say jack up the whole rear and unbolt the whole bar and see if there's any place it's rubbing. It's not too difficult if you have some jackstands and such.
Squishface
09-15-2015 06:51 AM
killahXB2
03-27-2015 10:45 AM
757_BRDFLY
01-09-2015 12:29 PM
TheTripleC
01-04-2015 06:46 PM
yamahamx117
Scion xD Suspension & Handling
12-25-2014 01:54 PM
Quick Reply: OEM rear sway bar squeaking? HELP!!
